Axminster Trade AT3327B Bandsaw
- Max depth of cut 300mm, max width of cut 410mm
- Braked induction motor and electrically interlocked doors for safety
- Twin dust ports for efficient extraction, 1200m³/hr airflow required
Customers Also Bought
A bandsaw is probably the most versatile machine in any workshop and often the first machine used when preparing timber. With a powerful motor, large capacities and made to the exacting standards we expect of our Trade range of machines, this bandsaw has become firmly established. It offers excellent safety features including braked motor and interlocked doors and twin extraction ports. A rigid welded steel chassis, cast iron table and heavy duty bearing blade guides are standard, along with a rigid rip fence and precision mitre fence. One often overlooked feature is the ease of changing the blade; it has a quick release blade tensioning lever which substantially speeds up the process of blade changing. Two belt speeds offer the right speed for the job, big or small. A wide range of blades is available, all made here in Axminster. First class build quality, ease of use and versatility mark this bandsaw out as a top machine for trade use. Supplied with rip fence, mitre fence and 1/2" x 6tpi bandsaw blade. N.B. 16A supply required.
This machine was previously known as the SBW4300B.
- Cast iron table, ground surface finish with a 19mm T slot
- Heavy duty bearing guides hold the blade securely for accuracy
- Rigid rip fence with magnified scale lens and accurate mitre fence
- Quick release blade tensioning lever eases blade changing
