Our stores are now open! (Sittingbourne remains Click & Collect only) Find your nearest store
Axminster Trade Ultimate Edge Reverse Running Sharpening System
105529
£369.96 £308.30
In Stock
- get it Friday 16th Apr, order within and choose Premium delivery. Delivery info
  • Simple, well built machine for light grinding/sharpening
  • Single speed 375W induction motor produces plenty of power
  • Compound Jig included
Customers Also Bought
Everything you need to keep the ultimate edge on your tools
With these optional accessories, this machine becomes a truly exceptional sharpening and honing system.
Many of the Tormek jigs can also be utilised.
Watch our woodturning tool sharpening guide
Compound Jig
The basis of most options for the Ultimate Edge is the Compound Jig and is included with your Axminster Trade Ultimate Edge machine. This jig has the familiar round bar in ground silver steel to allow many of the Tormek jigs to be mounted. A clever system of sliding the bar in two directions in one operation is employed, locked with just a twist of a handle.
Find out more
Universal Sharpening Table
The table locks securely onto the round bar of the Compound Jig forming a stable platform. Anodised in black, there is a quadrant of angles laser-marked into the surface for easy reference. The Sharpening Table is ideal for freehand lathe tool sharpening and general linishing. The supplied mitre guide also helps to maintain the position of the grind. Size 130 x 75mm.
Find out more
Honing Guide
Perfect for plane blades and joinery chisels, it fits onto the round bar of the Compound Jig. The blade is clamped tightly allowing both primary and secondary bevels to be achieved. It is manufactured entirely from stainless steel and has a simple set screw to control the width. The LH jaw is reversible and has twin jaws. One curved so that chisels that do not have perfectly parallel sides (such as Japanese styles) can be clamped; the other jaw being parallel. The jaws are of a dovetail shape, allowing the chisel to be securely clamped against the body. The jaws accommodate chisels from 6-66mm in width, so even a No. 8 plane blade will fit.
Find out more
'Twist n Fix' Arbor
The 'Twist n Fix' arbor does just that, one twist and it's fixed in place on the carrier. The unique connection allows mops and honing wheels to be used in either forward or in reverse. Polishing mops and felt wheels should always be used in order, working from a coarse to a fine compound. Separate arbors are available so each mop or wheel can be left attached for fast-changing.
Find out more
Chisel & Plane Blade Sharpening Jig
Having ground the primary bevel on any tool it is actually a secondary bevel or micro bevel that does most of the work. This jig allows the secondary bevel to be increased with ease each time the tool becomes dull.
Find out more
Honing Belt
Designed to use specifically with the Ultimate Edge. It is made from two layers of supple leather, 3.5mm thick, and double-sided. This means that two grades of honing or polishing pastes can be used, the belt being flipped over to use the alternative side. The joints are butted, so there should be no high spots to disturb the process. Always use the belt in a clockwise direction, with the belt travelling away from the blade tip.
Find out more
Total: £453.20
The Axminster Trade Ultimate Edge is a new way of sharpening, linishing and polishing. Now, none of us take up sharpening as a hobby, but it’s a necessity to get the best out of our tools; woodwork without a keen edge simply ends up in tears. With this fixed speed version, we’ve torn up the rule book and changed the direction of sharpening. When honing or stropping a fine edge, convention has always been away from the strop - I mean which way does the barber strop his razor…? Exactly, away from. Other belt sharpening machines will have the belt only travelling into the blade. Running the belt in reverse, away from the blade, gives you greater control, generating less heat and, ultimately, giving you a better (barber quality) edge.
The Compound Jig comes with this machine.
If you’re a woodworker who struggles to get the best edge on your tools, you will love the Ultimate Edge. With the right accessories, you cannot fail to get a fast, repeatable, quality edge every time. If you’re a skilled sharpener, the Ultimate Edge is also for you. Utilising the Universal Sharpening Table, allows you to freehand sharpen all your edge tools.
If woodturning is your craft, the Ultimate Edge takes care of your tools brilliantly. Once the Compound Jig is fitted to the machine it allows many of the outstanding Tormek jigs to be used, producing a honed edge on many tools, quickly and easily.
Carvers have not been forgotten either. With many carving tools being quite delicate, you don’t want to be too aggressive with them. This is where the unique Twist n Fix comes into its own. Once fitted to the Ultimate Edge, a wide range of mops and felt wheels can be fitted to bring your carving tools back to life.
We’ve also found the Ultimate Edge to be fantastic at bringing old tools back to life. If you have some of your grandad’s old tools in a box at the back of the shed, the Ultimate Edge combines fast rust removal with effortless polishing and incredible sharpening and honing capabilities. Remember, many of these old tools are made from the best steels available.
The possibilities of the Ultimate Edge are endless. This machine has a 375W induction motor, which has high torque and is quiet running. The 50mm wide belts can be easily changed with an auto tension lock and belt tracking is also quick and easy to adjust. The belt platter is fully adjustable to the belt; an optional graphite slip plate is provided. There is a simple table provided as standard. The base is 5mm plate steel and is provided with adjustable feet for bench mounting.
  • Machine runs in reverse for more effective and safer sharpening
  • 50mm wide abrasive belt, 496m/min belt speed
  • Very strongly built, able to withstand prolonged use
  • Very easy belt changing and tracking adjustment
  • Comprehensive range of options and abrasive belts available
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
