Axminster Woodturning
Axminster Woodturning Cylinder Jaws - 50mm
SKU: 310425
€115,00
  • Potential gripping range: Cylinder 45mm to 57mm
  • Internal and external dovetails on end of jaws
  • Potential gripping range: Internal dovetail 41mm to 60mm
  • Potential gripping range: External dovetail 60mm to 73mm
  • Recommended for GK100, SK100 and SK114 chucks
  • Drawing dimensions taken when jaws form a true circle
  • Grips blank along a substantial length
  • Made in the UK
When turning long and thin projects it's a great advantage to be able to grip a blank along a substantial amount of its length to impart a good measure of stability to the workpiece. To overcome this problem we have designed these Cylinder Jaws a 50mm diameter by 43mm long bore to accommodate a range of workpiece diameters. In addition, because we are always loath to provide you with jaws which perform only one function, we have added internal and external dovetails on the ends. Suitable for GK100, SK100 and SK114 chucks only. As with all our dovetail jaws they simply bolt onto the Accessory Mounting Jaws.
Made in Britain Yes
Jaws For 100mm Chuck Yes
Jaws For 114mm Chuck Yes
Intended Use For gripping larger, cylindrical workpieces during woodturning.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511011926
