Axminster Woodturning Polishing Set for Twist & Fix Adaptor & Mop Arbor
- Buff and compound set to use alongside Axminster Woodturning Twist & Fix Adaptor and Mop Arbor
- Includes various mop and compounds
- A complete set with everything you need to get started
Axminster Woodturning Twist & Fix - M33 x 3.5mm Euro ASR GrooveSpecial Price £41.98 £34.98 was £59.98 £49.98 Save £18.00 £15.00
Axminster Woodturning Twist & Fix Adaptor & Mop Arbor - 1.1/4" x 8tpiSpecial Price £41.98 £34.98 was £59.98 £49.98 Save £18.00 £15.00
Switch between a variety of mops and compounds easily with the Axminster Woodturning Polishing Set for Twist & Fix Adaptor and Mop Arbour. The kit is supplied with 2 x stitched mops, 1 x 60 fold loose leaf, 1 x brown compound, 1 x buff compound, 1 x carnauba block.
Stitched mops: stitched mops have a firm face and are useful for the first and second (if required) stages of the polishing process.
60 fold loose leaf mops: these consist of layers of cotton material left unstitched for a softer working surface. Use with the finest compounds for final polishing.
Brown compound: ideal for the first polishing stages and general purpose polishing.
Buff compound: Use the buff compound with the loose leaf mop for final polishing.
Carnauba block: this leaves a tough and hard wearing finish. It works best when on small turned items and leaves a long lasting bright gloss finish.
For best results, use a separate mop for each compound.
EAN Barcode | 5056402217398 |
- Standard Delivery* - Free
