Axminster Woodturning
Axminster Woodturning Screw Chuck for E Dovetail Jaws
SKU: 111990
€11,00
  • Compatible with the Dovetail Jaws Type E
  • Quickly mount a turning blank on the lathe
  • Grips firming onto the project blank
  • Ideal for smaller or shallow work pieces
  • Made in Axminster, UK
  • Perfect set up for anyone new to turning
This Axminster Woodturning Screw Chuck is compatible with the Dovetail Jaws Type E. Using a screw chuck is a quick and convenient method for a mounting a turning blank on your lathe.
The central screw has a deep sharp thread for a positive and secure hold. It only requires you to drill a single shallow hole in the blank. Unlike a face plate which requires several screws to attach the timber, a screw chuck has a single central screw. It is ideal for smaller or shallow workpieces, (always assess the suitability for the size of the work).
Made entirely in Axminster, UK.
Intended Use Quickly mount a turning blank on the lathe
Web Attribute Set Wood Screw Chucks
EAN Barcode 5052511137244
