Axminster Woodturning Diameter Calipers
- Available in large or small to cover most measuring situations
- Set contains an inside/outside pair for checking diameters
- Made from stainless steel, in the UK
Axminster Woodturning Speed SizerSpecial Price £19.98 £16.65 was £27.68 £23.07 Save £7.70 £6.42
These turner's calipers contain an inside/outside pair for checking diameters. The two ends of the calipers produce the same setting, allowing measurements to be made without removing the calipers from the work. If you are working with wet timber, these calipers are perfect as they are stainless steel, therefore corrosion resistant.
Capacities are:
Small set - 190mm
Large set - 260mm
These calipers are made in Axminster, UK.
