The Axminster 5W LED Worklight is perfect for work that is to be carried out in darker lit spaces. Its super bright white light has an even spread to ensure your workspace will be lit accordingly.
Designed to be used with machinery, it can be securely bolted onto machines. It has a flexible 10 x 420mm swan neck making it fully adjustable to suit your desired location. It has an all metal construction. Due to the low wattage LED bulb, this light generates limited heat.
Length of Cable 1.6 m
EAN Barcode 5052511138913
