Perfect for craft projects
Supplied with 19, 23, 35, 42 and 50mm spindles to cover a variety of projects, this bobbin sander is ideal for sanding and refining complex curves for crafts and small projects, and ideal for use in a small workspace.
Buy with confidence
Easy adjustments
Easy adjustments
The table adjusts from 0° to 45° which allows for accurate sanding. This gives you the flexibility to work on various projects with ease.
Strong and sturdy construction
Strong and sturdy
The rigid steel frame and cast iron top aids reduction in vibration for a more comfortable woodworking experience.
Plenty of power
Plenty of power
The 370W motor is quiet and powerful, yet slow running as to not burn your work.
Dust extraction guard
The efficient dust extraction guard helps to keep you safe and your workspace clean.
Simple storage solutions
There's built in storage for spindles and table inserts meaning you can keep all parts in one place!
Perfect for...
Perfect for…
The AW140BS is ideal for sanding complex curves and creating bevels, all without the risk of burning your wood. The sander also comes with 19, 23, 35, 42 and 50mm abrasive sleeves for a range of tasks.
The Axminster Workshop AW140BS Bobbin Sander is perfect for sanding and refining curves and edges. The bobbin oscillates vertically, leaving a smooth, clean finish which also prevents burning and spreads the wear of the sanding sleeve.
It has a cast iron table that tilts up to 45 degrees and locks firmly in place. The 370W motor is quiet in use and slow running as to not burn your work. Dust extraction is via a 50mm port on the rear and should be connected to a suitable vacuum extractor. The sander has a rigid steel frame and cast iron top, which helps to reduce vibration. There is also storage space for spare bobbins.
This Bobbin Sander is ideal for crafts and small projects, perfect for small workspaces. Supplied with 19, 23, 35, 42 and 50mm bobbin sizes and abrasives.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 44 mm I.D. / 50 mm O.D.
Power 370 W
Rating Regular Use
Stroke Length 22 mm
Table Height 485 mm
Table Size 375 mm x 375 mm
Plug Fitted UK 3 pin plug
Model AW140BS
Bobbin Height 140 mm
Max Cap @ 90º 110 mm
Nett Weight 33 kg
Spindle Speed 1,425 rpm
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511136254
Accessories
  • Axminster EU Power Cable - C19 - 2m
