Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
This oscillating bobbin sander is invaluable when it comes to sanding and refining curves, especially concave shapes and for finishing small parts. The bobbin oscillates vertically, leaving a smooth finish whilst also spreading the wear over more of the sanding sleeve. The cast iron table tilts up to 45° and has several nylon table inserts to give a close fit around the bobbin. The 370W induction motor is quiet in use and slow running so as not to burn your work. The base is fabricated in sheet steel and has storage for spare bobbins and table inserts. Dust extraction is via a 50mm port on the rear and should be connected to a suitable vacuum extractor.
This uncomplicated but sturdy machine would be a great asset for crafts and small projects. Supplied with 19mm, 38mm, 50mm and 76mm bobbins. It is also supplied with 19mm and 50mm abrasives.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Invaluable for sanding and refining curves, especially concave shapes
Bobbin oscillates vertically leaving a smooth finish
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
