The AW1500DE Dust Extractor is ideal for use with larger machines and easily manages dust extraction for multiple tools in the workshop. Powered by a 1.5kW motor, it delivers 1,546m³/hr airflow, ensuring to keep your workspace safe and clean. It's perfect paired with machines that produce large volumes of waste, such as planer thicknessers.
Delivering 5-micron filtration, it effectively captures larger dust particles and shavings with ease. Its balanced steel impeller ensures long life and consistent performance, even when connected to machines that generate heavy waste. Even with its strong performance, this extractor offers great value, delivering effective dust control.
Designed with practicality in mind, the AW1500DE Dust Extractor is easy to move around the workshop thanks to its large wheels. Bag clips and quick-fit straps allow for fast and effortless bag changes, helping you keep the machine running with minimal downtime.
It has a bag capacity of 153L and features a main inlet of 125mm or the option to connect two machines at once via the two 100mm outlets.
Airflow: as measured in the Axminster Workshop 1,546m³/hr airflow @ 125mm.
Airflow 1,546 m³/hr @ 125 mm
Filter Performance 5 micron
Overall L x W x H 1035 x 653 x 1983 mm
Power 1.5 kW
Rating Regular Use
Sound Power Level LwA [Uncertainty K] 83 dB(A)
Plug Fitted UK 3 pin plug
Bag Capacity 153 litre
Hose Diameter 1 x 125 mm or 2 x 100 mm
Nett Weight 41.5 kg
Static Pressure 2,000 Pa
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511142415
