Quietly clean and filter your workshop
Especially suited to areas where hand sanding takes place, the quiet, powerful and easy to install unit works alongside a chip or dust extractor to help clean the air in your workspace.
Axminster Workshop AW15AFS Air Filter - 230V
Buy with confidence
Perfect for the average home workshop or garage
Easy to install, the powerful and quiet unit can be used as part of your dust extraction system. Ideal for home workshops up to 155m³
Active Flow Sensor
This detects when the filter becomes blocked and the lights flash accompanied by a beep to notify that it needs cleaning. Keep the air filter operating at optimum performance.
Handy remote control
Supplied with the machine, choose between three settings for time and speed. Set the machine to continue to clean the air even after work has finished for the day.
Optional charcoal filter
For best results use with the Inner Filter to remove odours and neutralise harmful organic fumes as well as filtering particles such as pollen.
Find out more
With a quiet 95W motor, the AW15AFS Air Filter is perfect for the average home workshop, especially where hand sanding takes place. The air passes through an electrostatic pre-filter into the main pleated filter, filtering 98% of all particles 5 microns in size and 86% of all particles 1 micron in size.
The remote control unit has three settings for the motor speed and three time settings; 1, 2 or 4 hours, which can be used to clear the workshop after work has finished for the day. (Mains cable 2m)
Optional accessories include a charcoal filter, which neutralises odours and harmful organic fumes or particles including pollen.
A handy ceiling mounting kit consisting of 4 lengths of flexible stainless steel wire with screw eyes and bolt up crimps allows the machine to be positioned out of the way.
Supplied with an electrostatic pre-filter, main filter and 4 mounting eyes. It needs a secure mounting capable of holding a 25kg static load, at least 2m off the ground. The machine runs reasonably quietly with noise levels of speed 1: 61dB, speed 2: 62dB, and speed 3: 64dB.
NB: The AW15AFS now comes with an 'Active Flow Sensor', which detects when the filter becomes blocked. When the filter is blocked an alarm will sound and the top row of lights on the control panel will start flashing. Once the filters are cleaned or replaced you will need to reset the system by holding in the 'on speed' button for around 10 seconds, then release.
*This air filter is suitable for removing dry airborne wood dust particles and should always be used in conjunction with a dust extractor.
Sound pressure levels (LpA, dB): 64 at high speed, 62 at medium speed, and 61 at low speed.
Please note, if you require an EU plug, please ensure you purchase 113504
Filter Performance 86% 1 micron
Overall L x W x H 515 mm x 431 mm x 312 mm
Rating Regular Use
Cable Length 2 m
Sound Pressure Level LpA [Uncertainty K] 64 dB(A)
Motor Power 95 W
Model AW15AFS
Air Movement 360, 480, 600 m/hr
Nett Weight 20 kg
Room Volume 155 m
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511125098
