Axminster Workshop AW18BDS Belt Disc Sander 230V
111998
Special Price £159.58 £132.98 was £189.98 £158.32 Save £30.40 £25.33
1 Review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Perfect for larger workpieces and projects
  • Ideal for detailing, shaping and more, including achieving mitres and compounds
  • Dust extraction outlets for both belt and disc
  • Supplied with a sanding disc and belt
For slightly larger projects…
The AW18BDS is ideal for slightly larger craft projects. It excels in detailing, shaping, finishing, and more, all with safety and ease.
Three year guarantee
Buy with confidence
AW18BDS - Suited to larger projects
Ideal for sanding larger workpieces, this sander is perfect for those tackling bigger projects or working in slightly larger workspaces.
AW18BDS - Compounds and mitres
The belt and disc tables can be tilted to 45° and features a mitre slot, so both mitres and compounds can be sanded.
AW18BDS - Dust extraction
Dust extraction
2 x 38mm dust outlets for efficient dust extraction when connected to a suitable vacuum extractor.
AW18BDS - Perfect for…
Perfect for…
Excellent for detailing, shaping, finishing and profiling on larger projects. It’s ideal for end grain work, fine-tuning angles and achieving mitres and compounds with ease.
The Axminster Workshop AW18BDS Belt & Disc Sander 230V is ideal for detailing, shaping, and finish sanding for those larger projects. It features a 25 x 1,067mm belt and a 150 x 200mm tilting table for profiling and finishing. The 200mm disc abrasive and 190 x 270mm table are perfect for end grain work and fine-tuning angles. Both tilting tables allow for precise detail work and achieving mitres and compounds with ease.
The machine includes two 38mm dust extraction outlets for both the belt and disc, a hook and loop sanding disc and belt, and a mitre gauge. It's perfect for working on larger projects that may require a larger sanding capacity.
Please note these machines are designed and manufactured for sanding wood and similar materials. It should not be used to abrade or grind metal.
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
5.00 1
