Axminster Workshop AW200WSG Wide Stone Grinder - 230V
- 200mm grinder for the keen woodworker
- 25mm wide 60 grit aluminium oxide wheel on the left
- 40mm wide 80 grit aluminium oxide wheel on the right-hand side
Axminster Workshop Adjustable Sharpening RestSpecial Price £43.38 £36.15 was £61.98 £51.65 Save £18.60 £15.50
This Axminster Workshop 200mm Wide Stone bench grinder answers both your grinding and sharpening needs. It features a 25mm wide, 60 grit aluminium oxide wheel on the left-hand side and a 40mm wide 80 grit aluminium oxide white wheel, on the right.
The 40mm stone is wide enough to accommodate turning tools and the majority of woodworking edge tools. White aluminium oxide has far less tendency to burn the edge of the tool. The base of the AW200WSG features a pull-out drawer you can use as a water trough. The eye shield on the right features a magnifying lens. Adjustable tool rests and spark guards are all included.
Note: When a grinder is new or when changing stones it is important to dress the stones to ensure the front face runs true. The grinder is supplied with a diamond dresser to ensure you get the most out of your grinder.
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Bore Size | 15.88 mm (5/8") |
EAN Barcode | 5052511125265 |
Grinding Wheel Diameter | 200 mm |
Model | AW200WSG |
Motor Power | 370 W |
Nett Weight | 18 kg |
Overall L x W x H | 420 mm x 310 mm x 315 mm |
Plug Fitted | UK 3 pin plug |
Rating | Home Workshop |
Voltage | 230 V |
Wheel Speed | 2,980 rpm |
Wheel Width | 25 mm & 40 mm |
- Standard Delivery* - Free
