Axminster Workshop AW216BTS Table Saw 230V
113762
From £599.98 £499.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Wednesday 16th Sep
  • Compact with an impressive cutting capacity
  • 60mm cutting capacity at 90° and 40mm at 45°
  • Quiet and powerful 1.1kW motor
  • Super smooth tilt and height adjustment
  • Tilt and height adjustment mechanism bolted to the chassis
  • Highly efficient dust extraction from above and below
  • Stand with sturdy leg design for complete stability
Powerful performance in a compact, robust design
The smaller of the two table saws in the Axminster Workshop range, the AW216BTS is ideal for smaller cutting tasks, whether for craft projects or DIY jobs. With a robust design, precision ground cast iron table, quiet motor and impressive cutting capacity for its size, it's a reliable, hard-working addition to any workshop.
Three year guarantee
Buy with confidence
Compact yet stable
Compact yet stable
The AW216BTS Table Saw is compact, making it ideal for cutting smaller pieces of timber with precision. Constructed from powder-coated steel, the sturdy leg design improves stability and provides a comfortable working height for greater control and ease of use.
Saw design
Saw design
The motor and saw arbor assembly is mounted on trunnions bolted onto the chassis, a feature which is reserved for much larger saws. This improves adjustability and allows for a much smoother blade rise and tilt function.
Quiet induction motor
Powered by a quiet 1.1 kW induction motor, this saw is ideal for use in residential areas where noise is a concern.
Cutting capacity
Cutting capacity
It offers impressive cutting capacities, with a 60 mm depth at 90° and 40 mm at 45°, plus a maximum rip width of 345 mm. The 790 x 925 mm precision ground cast iron table includes left, right and rear extensions, while the full-length rip fence features a sliding high/low sub-fence for added versatility. The saw is supplied with an Axcaliber Premium TCT Saw Blade 216 x 2.2 x 30mm 48T.
Safety features
Safety features
An NVR switch is included, with a separate lockable emergency stop function. This helps to protect users and the equipment from harm, providing quick shutdown when needed.
Dust extraction
Dust extraction
Keep the saw line clear with combined above-blade and below-table dust extraction, both feeding into a single outlet for easy connection to an extractor.
Get the best out of your AW216BTS
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
The Axminster Workshop AW216BTS Table Saw is an excellent, compact woodworking table saw for a home workshop, hobby woodworkers, DIY enthusiasts or for everyday woodworking tasks. Featuring a precision ground cast iron table, smooth chassis-mounted trunnion system and quiet 1.1kW induction motor, it delivers accurate cuts without taking up excessive workshop space. Slightly more compact than the AW254TS Table Saw, it is particularly well suited for cutting smaller timber pieces with precision, ideal for furniture projects and general woodworking tasks.
Powered by a quiet 1.1 kW induction motor, this saw is ideal for use in residential areas where noise is a concern. Its robust, precision ground cast iron table features 19 mm mitre fence T-slots on both sides of the blade, allowing workpieces to glide smoothly across the surface. Despite its compact size, it offers impressive cutting capacities: 60 mm depth at 90° and 40 mm at 45°, with a maximum rip width of 345 mm making it well suited to a wide variety of tasks. The table measures 790 x 925 mm and comes with left, right, and rear extensions for added versatility. The full-length rip fence includes a sliding sub-fence with high/low adjustment options.
The tilt and height adjustment mechanism and motor are bolted directly to the chassis rather than the underside of the table, ensuring exceptionally smooth operation without added stress from hanging components. This design provides precise, effortless adjustments, enabling a wide range of cuts for diverse woodworking applications.
Dust extraction on the AW216BTS Table Saw is highly efficient, combining above-blade and below-table extraction into a single port for connection to an extractor. Safety features include an NVR switch with a separate, lockable Emergency Stop function. Removable side panels make cleaning and maintenance quick and simple.
The sturdy stand features a compact leg design for stability, even when handling larger or heavier workpieces. Constructed from powder-coated steel, the stand raises the saw to a comfortable working height, and rubber feet keep it securely in place during use.
This compact table saw offers exceptional value while delivering impressive performance for its size. Ideal for home workshops, hobby woodworkers, furniture makers and DIY renovation projects, it's equally at home in a small professional workshop. Perfect for cutting smaller sheet materials and producing accurate rip cuts in both hardwood and softwood, it's a versatile addition to any workshop.
Supplied with an Axcaliber Premium TCT Saw Blade - 216mm x 2.2mm x 30mm 48T.
Please note, if you require an EU plug, please ensure you purchase 113504
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed and intended for those who require equipment for more regular, but not continuous, operation. They must be maintained and serviced in line with our schedule; otherwise guarantee may be void.
Learn more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
