Improve both your precision and your efficiency
If you’re on the lookout for a table saw to help you achieve your woodworking ambitions, look no further. Our powerful AW254TS Table Saw brings the cutting capacity of a trade workshop into the home workshop, making it ideal for many types of crafts and DIY projects. Supplied with extension tables, useful for cutting longer pieces of wood.
Buy with confidence
Person cuts a piece of wood on an Axminster Workshop table saw
Fantastic cutting capacity
Enjoy large, accurate and fast cutting 80mm capacity with this table saw; a real workhorse of any home workshop.
A person using a table saw to cut a piece of wood, with a flexible metal dust collector hose connected to the saw. The table saw has a grey top, a white base, and a red blade guard.
Stable and robust
The ground cast iron table allows your workpiece to run smoothly across the table while the rigid rip fence offers maximum support while you work.
Person cuts a piece of wood on an Axminster Workshop AW254TS Table Saw
Achieve multiple cuts
The AW254TS allows you to achieve a range of different cuts including straight cuts, mitred cuts and bevel cuts for a range of different materials including ply, MDF, sheet materials and more.
Axminster Workshop AW254TS Table Saw shown against a wood panelled background
Increased table width
As well as providing stability, the left, right and rear extension tables give you a total table width overall of 1,060mm. Useful for cutting longer pieces of wood or sheet materials.
Axminster Workshop Table Saw with the table removed to reveal the workings and design of the machine
Saw design
The motor and saw arbor assembly is mounted on trunnions bolted onto the chassis, a feature which is reserved for much larger saws. This improves adjustability and allows for a much smoother blade rise and tilt function.
A table saw with a grey tabletop and silver blade, featuring a red dust collector attachment and flexible grey hose, set against a wood-panelled wall. Shows the dual extraction ports
Dual dust extraction ports
Keep the saw line clear with a 63mm blade guard hose connection to clear above the blade, as well as a 100mm rear outlet to clear below.
Choose your blade
You'll benefit from quiet and smooth cuts, plus a long service life.
The AW254TS Workshop table saw bench brings the cutting capacity of the trade workshop into the home workshop.
The saw features a quiet 1,500W induction motor, an important consideration in a residential neighbourhood. The generous cast iron table comes with the benefit 19mm mitre fence T-slots on the right and left of the blade, allowing your workpiece to run smoothly across the table. A 254mm Axcaliber Premium 40 tooth blade, offers a maximum 80mm depth of cut for quality cutting. The full length rip fence includes a sliding sub fence with high/low functions.
The tilt and height adjustment mechanism is bolted to the chassis as opposed to the underside of the table. The result is exceptionally smooth operation and adjustability, without any weight hanging beneath the table causing stress. The tilt and height adjustments allow you to achieve a range of cuts for varied applications.
Efficient dust extraction from above the blade and below the table is brought to a single 100mm dust port for connection to an extractor. The NVR switch includes a separate locking Emergency Stop function. Removable side panels to allow cleaning and maintenance. The AW254TS is supplied with left, right and rear extension tables, giving you a total table width of 1,060mm. This is particularly useful for cutting longer pieces of wood or sheet materials.
The stand has a splayed leg design to ensure stability even when cutting large or heavy work pieces. The legs and cross braces are powder coated steel. The stand raises your saw to a comfortable height and rubber feet prevent the saw from moving when in use.
Please note, if you require an EU plug, please ensure you purchase 113504
Blade Tilt 0 to 45
Dust Extraction Outlet 100 mm & 63 mm
Max Depth of Cut @ 45º 56 mm
Max Depth of Cut @ 90º 80 mm
Max Width of Cut with Fence 430 mm with R/H Ext
Overall L x W x H 1,070 mm x 1,230 mm x 1,200 mm
Power 1.5 kW
Rating Regular Use
T Slot Size 19 mm x 9.5 mm (3/4" x 3/8")
Table Height 900 mm
Table Size 485 mm x 680 mm
Blade Diameter 254 mm
Min Extraction Airflow Required 1,000 m³/hr
Sound Power Level LwA [Uncertainty K] 94 dB(A) [3.0 dB]
Blade RPM 3,000 rpm
Sound Pressure Level LpA [Uncertainty K] 78 dB(A) [3.0 dB]
Plug Fitted UK 3 pin plug
Bore Size 30 mm
Nett Weight 109 kg
Table Size With Extensions 1060 mm x 900 mm
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511135820
