A machine you can depend on
Whatever the task, this machine will accurately slice thin veneers or resaw large chunks of timber. Don’t forget to take a look at our wide range of blades for every task.
Buy with confidence
Person cuts a live edge board with a bandsaw
Large capacity
A large cast iron table and ability to make deep wide cuts makes this a very versatile machine. The backbone to any home workshop.
Person removes cover on a bandsaw to reveal the ball bearing blade guides
Ball bearing blade guides
The ball bearing blade guides make the bandsaw easier to set up and also help to achieve more accuracy when cutting.
Dust extraction outlet on an Axminster Workshop Bandsaw
Excellent dust extraction
With dual extraction ports, you can rest assured you’re safeguarding not only your health, but keeping your workshop clean at the same time.
Twin trunnion table support on an Axminster Workshop bandsaw
This provides excellent support and aids towards a vibration free cut.
Images shows the interlocking doors which is a safety feature on Axminster Workshop bandsaws
Safety first
Supplied with push stick and interlocked doors for added safety.
Motor housing on an Axminster Workshop bandsaw
Plenty of power
Supplied with a powerful alloy bodied motor with a multi v drive transfers maximum power to the blade.
A close-up of a bandsaw cutting a sheet of material over a wooden surface, with the AXCALIBER brand name and a British Made badge visible on the image.
Choose your blade
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Purchasing the AW2606B puts a powerful large capacity bandsaw in your workshop. A machine on which you can depend on to accurately slice thin veneers or resaw large chunks of timber, (we offer a wide range of blades for every task).
A powerful, quiet and reliable alloy bodied induction motor drives the bandsaw through a multi V-belt . A choice of two blade speeds, gives you the right speed for any task.
The AW2606B has a strong fabricated steel frame with a cast iron table and mountings. The generously sized, cast iron table has a standard 19mm mitre fence slot. The rip fence cam locks solidly to the front rail. Twin scales allow the fence to be used either side of the blade.
Bearing guides offer excellent support for increased accuracy. A rack and pinion system provides easy adjustment of the upper blade guide.
The two dust extraction points are interconnected and joined to a single 100mm outlet for coupling to a suitable extractor. Supplied with a splayed leg steel stand with rubber feet and a UK made general purpose 1/2 x 4tpi blade.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 100 mm
Max Width of Cut with Fence 260 mm
Overall L x W x H 980 mm x 760 mm x 1,740 mm
Power 1.1 kW
Rating Regular Use
T Slot Size 19 mm x 9.5 mm (3/4" x 3/8")
Table Height 1,060 mm
Table Size 485 mm x 550 mm
Table Tilt 0 - 45
Min Extraction Airflow Required 1,000 m³/hr
Sound Power Level LwA [Uncertainty K] 98.5 dB(A) [3.0 dB]
Sound Pressure Level LpA [Uncertainty K] 84 dB(A) [3.0 dB]
Plug Fitted UK 3 pin plug
Model AW2606B
Bandsaw Blade Length 2,606 mm (102.3/4")
Bandsaw Wheel Diameter 370 mm
Blade Speed 600 & 840 m/min
Blade Width Min\Max 6 mm to 19 mm
Max Cutting Height 200 mm
Max Width of Cut 360 mm
Nett Weight 85 kg
Table Height on Stand N/A
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511126309
This is a Two-Person Large Delivery service. A two-person carrier dedicated to delivering larger and heavier consumer goods into your room of choice; whether in the home (including garden and garage) or at a business address. The carrier will inform you of your delivery options.
  • UK Mainland - £70
