Axminster Workshop AW2606B Bandsaw Kit
720994
From £739.98 £616.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Resaw thick timber or cut thin veneers
  • Large depth of cut: 200mm with 360mm width of cut
  • Rigid, quick locking rip fence, cast iron table
  • Kit to include bandsaw, UJK bandsaw buddy, mitre fence and blades
This kit is supplied with the AW2606B Bandsaw, UJK Bandsaw Buddy, Axminster Workshop Mitre Fence for 19mm Slots and 5 Axcaliber Bandsaw Blades comprising of 1/4" x 6 tpi, 1/4" x 10 tpi, 3/8" x 4 tpi, 3/8" x 6 tpi and 1/2" x 6 tpi.
Purchasing the AW2606B puts a powerful large capacity bandsaw in your workshop. A machine on which you can depend on to accurately slice thin veneers or resaw large chunks of timber, (we offer a wide range of blades for every task).
A powerful, quiet and reliable alloy bodied induction motor drives the bandsaw through a multi V-belt . A choice of two blade speeds, gives you the right speed for any task.
The AW2606B has a strong fabricated steel frame with a cast iron table and mountings. The generously sized, cast iron table has a standard 19mm mitre fence slot. The rip fence cam locks solidly to the front rail. Twin scales allow the fence to be used either side of the blade.
Bearing guides offer excellent support for increased accuracy. A rack and pinion system provides easy adjustment of the upper blade guide.
The two dust extraction points are interconnected and joined to a single 100mm outlet for coupling to a suitable extractor. Supplied with a splayed leg steel stand with rubber feet and a UK made general purpose 1/2" x 4tpi blade.
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
