A good size bench pillar drill enabling you to drill accurate holes at consistent depths and angles.
Made from cast iron and machined steel it’s sturdy, stable and strong. The keyless chuck is an excellent feature with a capacity of 1 to 16mm. Powered by a 550W induction motor, there are 12 belt speeds to choose from between 210-2,580rpm. The down feed is fitted with soft grip handles and there is a convenient drilling depth control. Table height is controlled via a rack and pinion system, the whole table assembly can be swivelled away to allow the base to be used as a work support. A front mounted NVR switch and the adjustable chuck guard add to the convenience of use. The belt cover has a safety switch to ensure safe speed changing.
A great choice for any hobby workshop.
Please note: the AW315PD is not suitable for a morticing attachment.
Please note, if you require an EU plug, please ensure you purchase 113504
Overall L x W x H 520 mm x 260 mm x 840 mm
Power 550 W
Rating Regular Use
Table Size 198 mm x 198 mm
Table Tilt 45 - 0 - 45
Chuck Capacity 1 mm to 16 mm
Chuck Type keyless
Throat Depth 127 mm
Plug Fitted UK 3 pin plug
Model AW315PD
Base Size 340 mm x 220 mm
Chuck Travel 60 mm
Collar Size 60 mm
Diameter of Column 60 mm
Max Chuck to Base 430 mm
Max Chuck to Table 315 mm
Max Drilling Mild Steel 16 mm
Nett Weight 37 kg
Speed Range 210 - 2,580 rpm (12)
Voltage 230 V
Warranty Axminster Workshop 3 Year Guarantee
EAN Barcode 5052511125159
