Axminster Workshop AD355WL Woodturning Lathe - 230V
107701
From £569.98 £474.98
205 Reviews
Includes 50% woodturning course discount
Learn more...
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 6th Oct
  • Cast iron bed headstock and tailstock ensure minimal vibration
  • Powerful 750W DC motor, quiet and smooth operation
  • Variable speed with spindle speeds from 250-3,550rpm
For those wanting to turn their hand to slightly larger projects
Perfect for if you aim to turn larger projects, due to the increased capacity and mini bed extension, which extends the distance between the centres even further.
Please note that the lathe shown in this video features an earlier colour version. The current model has updated branding colours, but its design, features, and performance are identical.
Three year guarantee
Buy with confidence
Variable speed drive
The variable speed control unit enables you to adjust the speed to suit your project; delicate work, larger diameters or out of balance work pieces. The LED digital read-out of the spindle speed in RPM, makes it easier to stay in control.
Motor
Motor
A 750 watt universal DC motor with electronic speed control and 3 speed pulley provides full torque at all speeds.
Great capacity with potential to increase
With 510mm between centres (depending on centres fitted) and a bowl turning capacity of 355mm, many ambitious projects can be undertaken. Plus, with the supplied mini bed extension, you can increase your distance to 740mm. Image is shown with the bed extension attached.
Cast iron construction
The cast iron construction ensures stability and reliability. The bed is made from cast iron, helping to reduce vibration.
Supplied with Axminster Woodturning Centres
Supplied with Axminster Woodturning centres
The lathe is supplied with high quality stainless steel Four Prong Drive and Revolving Tailstock Centres; both designed and manufactured in Axminster, UK.
Perfect for various projects...
Perfect for...
The AD355WL is an ideal upgrade due to its increased capacity, or perfect for those more ambitious beginners who aim to turn larger projects.
Buy any Axminster Workshop lathe to claim these offers!
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
  1. Axminster Workshop AD355WL Woodturning Lathe - 230V
Total:
£604.22 £503.52
The AD355WL is perfect for those woodturners looking to move up from a smaller lathe, or as a first lathe for the more ambitious newcomer. With a capacity of 510mm between centres (depending on the centres fitted) and with a bowl turning capacity of 355mm, many ambitious projects can be undertaken. Use the Mini Bed Extension to increase your distance between centres to 740mm.
Made from grey cast iron, the stability and vibration absorbing properties will be much appreciated. Featuring a top quality DC brush motor, with variable speed, three belt ratios and reverse. It has a speed range to suit every project within its capacities. A spindle speed readout helps select the appropriate speed for the job.
The headstock has large bearings to support the spindle, a flip-up cover allows easy access to the multi-V belt for speed ratio changing. There is a 24-stop indexing facility, with a spring-loaded indent pin to hold the spindle into position. The spindle thread is M33 x 3.5, allowing many accessories to be fitted. It has a 2MT for centres.
Cam locks secure both the tailstock and tool rest holder, and both are easy to move along the bed.
Mounted on rubber feet and supplied with Axminster drive and tailstock centres, 200mm tool rest, 100mm faceplate and Axminster Workshop Mini Bed Extension.
Please note, if you require an EU plug, please ensure you purchase 113504
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed and intended for those who require equipment for more regular, but not continuous, operation. They must be maintained and serviced in line with our schedule; otherwise guarantee may be void.
Learn more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.86 205
