Axminster Workshop AW370WL Variable Speed Woodturning Lathe - 230V
107700
Special Price £479.98 £399.98 was £579.98 £483.32 Save £100.00 £83.33
In Stock
- large delivery, normally within 3 to 5 working days. Delivery info
  • Variomatic speed control 500 to 2,000rpm (10 steps)
  • Swivelling headstock indexed at 45° and 90°
  • Complete with floor stand, centres, faceplate, tool rest extension and 300mm tool rest
Customers Also Bought
Axminster Workshop AW370WL Woodturning Lathe
Powerful and efficient, the Axminster Workshop AW370WL never fails to impress with its performance. Ideal for many types of projects, this floor standing lathe would make a great addition to any home workshop.
Free introduction to woodturning session
Purchase an Axminster Workshop lathe and you’ll get access to an Introduction to Woodturning session in any of our retail stores. The introduction will give you an understanding of the machine, including set up and safe usage, as well as what tools, accessories and materials are suited to your projects - so you can get on with the important decisions of what to make! Find out more
Buy with confidence
So sure are we of the quality of this lathe, we cover all parts and labour free of charge for three years! Find out more
Large capacity
An impressive maximum turning diameter of 370mm over the bed, and 1,100mm between centres; this is an excellent entry level floor standing lathe that offers large capacity with great value.
Wide speed range
The speed range is between 500 rpm and 2000 rpm, giving the user a range of speed options suitable for both delicate work, large diameters and out of balance workpieces.
Reliable
All cast iron construction gives the user high stability and vibration free running.
Swivel headstock
The headstock swivels to a preset 45 and 90 degrees angles and can be rotated, giving you better access when turning bowls and hollow forms. It also slides along the length of the bed, giving you the ability to set the headstock in the most convenient position.
Supplied with high quality accessories
The lathe is supplied with floorstand, faceplate, tool rest and high quality stainless steel Four Prong Drive and Revolving Tailstock Centres; both designed and manufactured in Axminster, UK.
Total:
£781.32 £651.10
The AW370WL is a powerful cast iron woodturning lathe with plenty of capacity and a powerful motor to match the larger capabilities. This floor standing woodturning lathe has several major features that set it apart for lathes within a similar range.
The centre height is a full 185mm giving it a massive 370mm maximum diameter for turning a bowl over the bed.
The distance between centres is a very useful 1,100mm for turning longer spindles and similar items. The headstock swivels and can slide along the length of the bed, giving the facility to set the headstock in the most convenient position to suit the work. The speed change system has ten steps which gives a wide range of speed options. With a simple twist of a lever you can switch between the following speeds;
Step 1 - 500 rpm
Step 2 - 620 rpm
Step 3 - 760 rpm
Step 4 - 900 rpm
Step 5 - 1050 rpm
Step 6 - 1210 rpm
Step 7 - 1400 rpm
Step 8 - 1590 rpm
Step 9 - 1790 rpm
Step 10 - 2000 rpm
Supplied with 4-prong Axminster drive centre, Axminster revolving tailstock centre, 150mm faceplate, outboard tool rest extension, 300mm tool rest and floor stand.
N.B. The distance between centres will vary slightly depending on the type of centres used.
Warranty Axminster Workshop 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.60 73
