Axminster Workshop AW457SS Scroll Saw
111916
From £249.98 £208.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 22nd Jul
  • 120W motor with a variable speed of 550 to 1,550/min
  • 457mm throat depth to allow for larger projects
  • 350 x 540mm table that tilts to 45° for bevel cutting
  • Dust extraction port for safe working
Perfect for any woodworking enthusiast
Looking for a scroll saw that can do it all? The AW457SS is perfect for intricate woodworking projects whilst still accommodating larger ones. It ensures smooth and accurate cutting for excellent results.
Three year guarantee
Buy with confidence
Variable Speed
Variable speed
The variable speed capacity, ranging from 550 to 1,550 strokes per minute, enables the machine to handle various materials, providing full control over cutting speed.
Cutting Capacity
Large cutting capacity
The AW457SS features a 350 x 540mm table, a 457mm throat depth and a 20mm stroke length, ideal for larger projects.
Stable Build
Stable build
The base is crafted from heavy gauge steel plate, ensuring minimal vibration for your projects.
Dust Extraction
Dust extraction
Connect your scroll saw using a vacuum cleaner via the 37mm diameter dust port to ensure safe working.
Tilting Arm
Tilting & raised arm
The arm tilts to a 45° angle in both directions while the table remains flat, ensuring easier and more precise cutting. It also raises, ensuring quick blade threading when making internal pierced cuts.
Supplied with a range of blades
The saw is supplied with a range of blades and accepts both pinned and plain end blades. This makes it excellent for cutting wood, metal and plastic. The blade changing is simple thanks to a quick release tension knob.
Scroll Saw Blades
Choose from a selection of scroll saw blades
From wood-cutting to metal-cutting, explore our wide selection of high-performance blades, available in a variety of TPI (teeth per inch) configurations to suit every material and application.
  1. Axminster Workshop AW457SS Scroll Saw
Total:
£262.92 £219.10
The Axminster Workshop AW457SS Scroll Saw is a versatile and precise tool, ideal for intricate woodworking projects.
Powered by a 120W motor, it ensures smooth and accurate cuts with stroke length of 20mm. With adjustable strokes per minute ranging from 550 to 1,550/min, you have full control over the cutting speed and can cut materials up to 50mm deep.
The 350 x 540mm table with a 457mm throat depth, tilts to 45° in both directions, for bevel cutting and is ideal for handling larger workpieces. The arm also raises to ensure quick blade threading when making internal pierced cuts. The base and table are made from a heavy gauge steel plate, giving stability and helps to reduce vibration.
The saw accepts pinned or plain end blades. The clamps are easily accessible for blade changing. Additionally, the 37mm dust extraction outlet keeps your workspace clean and free of debris when paired with a vacuum, making this scroll saw a valuable addition to any workshop.
Suitable for wood, metal and plastic. Supplied with a blade fitted and the Pegas Wood Scroll Saw Blade Starter Pack.
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
