Axminster Combination Square Metric 150mm
- Adjustable for marking and transferring measurements
- Versatile tool for setting out, measuring and marking
- Cast iron stock with enamel finish
- Accurately machined on measuring faces
- Built-in level and hardened steel scriber
- Hard chromed steel blade with easy-read pearl finish
- Metric graduations in millimetres, marked every 10mm
Axminster Combination Square Metric 400mmSpecial Price £16.24 £13.53 was £24.98 £20.82 Save £8.74 £7.28 -
A combination square is probably one of the most useful and versatile tools you can buy for general setting out. It functions as a try square, 45° mitre square, rule, depth gauge, marking gauge and level. You can use it for measuring, marking, scribing, and comparing and transferring measurements.
The combination square features a 150mm stainless steel rule with a cast iron stock. The stock also incorporates a level bubble and a hardened steel scriber. The precision machined and ground cast iron stock guarantees accuracy. A knurled brass screw, locking the rule in place, is very positive and easy to use. The blade is hard-chromed with a pearl finish for maximum clarity, graduated in millimetres and marked every 10mm.
| Blade Length | 150 mm |
| EAN Barcode | 5052511108954 |
- Standard Delivery* - £5
