Axminster Workshop Double Edge Marking Knife
101166
101166
Special Price £20.38 £16.98 was £25.48 £21.23 Save £5.10 £4.25
29 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Thursday 10th Jul
  • Use left-handed or right-handed
  • Doubled bevelled, spear shaped blade
  • Quality steel blade holds a good edge
  • Wenge wood handle fixed with steel rivets
  • Overall length 150mm, blade 50mm long 20mm wide
  1. Axminster Workshop Double Edge Marking Knife
Total:
£83.32 £69.43
The 55° spear shaped blade with its double bevel means this knife is usable left-handed or right-handed. The back of the blade is flat allowing the knife to run along a square’s blade or straight edge. A wooden scale on each side attached with steel rivets form a comfortable handle. A knife line is far more precise than a pencil line. The cut line forms a register for a chisel or saw resulting in work that is more accurate. Overall length 150mm, blade length 50mm.
5.00 29
