Combination Squares
  • Bahco Combination Squares Bahco Combination Squares
    £11.98 - £23.71
  • Axminster Combination Square Metric 300mm Axminster Combination Square Metric 300mm
  • Axminster Combination Square Metric 150mm
  • Axminster Combination Square Metric 400mm
  • Axminster Combination Square Set 150mm (3 Piece) Axminster Combination Square Set 150mm (3 Piece)
  • Axminster Combination Square Set 300mm (4 Piece) Axminster Combination Square Set 300mm (4 Piece)
  • Stanley Die-Cast Combination Square 300mm (12")
  • Stanley Combination Metal Square 300mm (12")
Combination Squares
Combination squares are versatile measuring and marking tools used for checking 90° and 45° angles, measuring depths, setting machine fences and transferring accurate dimensions. Essential for woodworking, engineering, metalworking and workshop setup, they combine multiple functions in a single precision tool. Available in a range of blade lengths and configurations, combination squares help ensure accurate layout, cutting and assembly work. Browse the range to find the right combination square for your measuring and marking tasks.
