Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Aztek Yellow - Large Coverage Nozzle (1.02mm)
Code: 103923
  • Yellow nozzle 1.02mm
  • Excellent coverage for large areas
  • Easy clean and change nozzle
  • Simply threads into the end of the airbrush
  • Supplied in protective capsule
  • Suitable for Aztek AZ470L and AZ480L
  • Working pressure 15-40 psi
  • Show More
£9.95 (£8.29 Ex. VAT)
Low stock - get it tomorrow, Wednesday 3rd Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - £2.95
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Aztek's patented nozzle system makes it easy to clean and change nozzles to your specific airbrushing needs and obtain the desired effects.
The interchangeable nozzles contain the main needle and needle spring, and simply thread into the end of your airbrush. Each nozzle comes in a protective capsule.
The Aztek Yellow (1.02mm) nozzle gives excellent coverage for large areas including T-shirts, model car and truck bodies, and base colours, with thinned solvent-based enamels, airbrush colours and acrylic paints.
Suitable for Aztek AZ470L and AZ480L. Working pressure, 15-40 psi.
Promo
Aztek Airbrushes
Why Aztek?
Airbrushes are a versatile tool that, once mastered, are a fun and creative way to add colour and detail to your projects.
Aztek airbrushes have been designed to make the whole process of airbrushing quick and easy. Furthermore, the material used is impervious to solvents so you can rely on Aztek to last.
Easy to clean and maintain
Like many great tools in life, airbrushes require some tender loving care after each use.
Unlike standard airbrushes that require complete disassembly to clean and maintain, cleaning an Aztek airbrush is quick and simple. The Aztek body is designed to enable the paint to travel directly to and through the nozzle, entirely bypassing the airbrush body and leaving only the nozzle to clean.
Easy pattern changes
Pattern changes are made easier than ever with Aztek's tip technology. By simply unscrewing and changing the tips you can move quickly from one spray pattern to the next and eliminate the process of having to the adjust the needle.
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
