Bahco 10 Series Bowsaw
- Precision cutting easier than ever before
- Ergonomic handle, with built in knuckle protection
- Blade changing and tensioning adjustments are effortless
Customers Also Bought
A lightweight yet heavy-duty bowsaw for all round use. The integrated, ergonomic handle with its built in hand guard protects your knuckles. A unique mechanism in the handle makes blade changing and tensioning adjustments effortless. The sturdy blade fittings and high blade tension make precision cutting easier than ever before. The frame comes fitted with a blade, choose: Peg tooth for cutting dry wood and general applications; or the Raker tooth blade for cutting green or wet timber.
- Peg tooth for dry wood
- Raker tooth for green wood
- Size 755mm (30")
