Bahco Bowsaws
From £19.51 £16.26
1 Review
  • Large moulded grips
  • Finger/knuckle protectors
  • Easy change blade and tension mechanism
  • Supplied with peg tooth (dry cutting) blades
The 533mm(21") bowsaw has a frame, which tapers towards the tip to allow better access between branches. The 610mm(24") is of the standard bowsaw design. Both feature large moulded grips and finger/knuckle protectors, easy change blade and tension mechanism. Both come fitted with peg tooth blades. Two types of replacement blades are available: Peg tooth for cutting dry wood and general applications; or the Raker tooth blades for cutting green or wet timber. Saws and blades made in Sweden.
5.00 1
