The Powerfile has become a much valued tool for getting into tight spots to sand, shape and remove rust. Fitted with a 13mm wide straight sanding arm with a reach of 120mm, it has variable speed control allowing it to sand a variety of materials like wood, metal, ceramics plaster, plastics etc. It is ergonomically balanced with a cyclonic dust collection cassette to keep the user and the environment clean. The dust cassette retains dust from the powerfile in a compact and efficient unit with a pleated filter element easily removed for cleaning and emptying. Powered by 350W variable speed motor the standard straight arm supplied supports an abrasive belt 13mm wide. Supplied with 3 sanding belts.
2 Year Black and Decker Warranty.
Belt Speed 900 to 1,600 m/min (var)
Dust Collection Filter Box Supplied
Rating Home/Light Trade
Sound Power Level LwA [Uncertainty K] 95 dB(A) [3.0 dB]
Corded or Cordless Corded
Abrasive Belt Size 13 mm x 451 mm
Cable Length 3 m
Sound Pressure Level LpA [Uncertainty K] 84 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 1.7 m/s² [1.5 m/s²]
Motor Power 350 W
Plug Fitted UK 3 pin plug
Model KA900E
Nett Weight 1.6 kg
Voltage 230 V
EAN Barcode 5035048175170
