Choosing The Right Bandsaw Blade
Points to consider
Length
The most obvious piece of information you need to know is “how long is my blade?” This should be on the spec label on your machine, or in the instruction book. If you have neither, please call us for advice.
Bandsaw Blade Finder
Find by model or blade length... the easy bandsaw blade selector
Width
Secondly, you need to choose the width of blade. Always use the widest blade possible – it is stronger and will withstand greater feed pressures without flexing. Consult your machine manual for the maximum and minimum blade widths that it will accept.
If you are a woodturner, cutting bowl blanks with a bandsaw is both safe and effective. However, you will need to choose a blade that will cut the radius you need.
The minimum radius of curve for each blade width is as follows:
| Blade width | Minimum radius |
| 13mm (1/2″) | 63mm (2 1/2″) |
| 10mm (3/8″) | 27mm (1 1/16″) |
| 6mm (1/4″) | 19mm (3/4″) |
| 5mm (3/16″) | 13mm (1/2″) |
| 3mm (1/8″) | 10mm (3/8″) |
And, don’t forget. A blade used for a batch of cutting bowl blanks will not be much use for straight cutting. Cutting curves will disturb the set of the teeth on the blade, consequently making it impossible to cut in a straight line. So we advise you to keep your bowl blank cutting blades separate from other blades. We also have a specialist curve cutting blade, the Back Tooth blade, for details see below.
Tooth form & pitch
The third area to consider is tooth form and pitch. This will depend on the type of work you intend to do, i.e. rip cutting (with the grain) or cross cutting (across the grain). Generally, a skip tooth blade is used for rip cutting, whereas a regular or triangular tooth blade is for cross cutting.
The skip tooth is provided on coarse tooth blades, those with 3, 4 and 6 teeth per inch; it has a wide shallow gullet with plenty of space for waste to collect. Please note that the quality of the cut can be adversely affected by sawdust packing between the teeth.
3 tpi (skip form)
Used for deep cutting especially rip cuts. This blade will leave a rough sawn finish although slow feed rate and high tension will improve the finish of the cut.
4 tpi (skip form)
Good for general-purpose use with a degree of cutting across the grain and with the grain. A reasonable finish can be achieved with slower feed rates and good tension.
6 tpi (skip form)
The ideal general purpose blade suitable for cross cutting up to 150mm and ripping in sections up to 50mm thick, although thicker sections can be cut using slow feed.
The regular, or triangular, tooth form is provided on blades with 10 or more teeth per inch where, because of the reduced material removal, there is less need for waste storage.
10 tpi (regular)
Good for cutting plywood and MDF as well as non-ferrous metals and plastics. The finish is good when cutting natural timbers, but the feed rate should be slow and maximum depth of cut should not exceed 50mm. When cutting metals, reduce the speed as much as possible especially when cutting ferrous metals or cast iron.
14, 24 and 32 tpi (regular)
A very clean cutting blade for plywood, plastics and MDF, although too fine for natural timbers unless they are very thin sections (sub 25mm thick). The 14tpi and above blades are very good to use at slow speeds when cutting non-ferrous metals. A slow feed speed should be used at all times with a blade tooth pitch this fine.
Blades with variable pitch teeth (4-6tpi, 6-10tpi and 10-14tpi) are also available for wider ranging applications (see Premium Bandsaw Blades).
Types
Now that you have made the three basic choices, we will guide you through the types of blades that we offer. Depending on the length of blade required, it can be an easy choice or a little more complex. For machines with a blade length up to 70 1/12”, we supply high carbon blades only. This is because small machines need a highly flexible blade to accommodate small diameter wheels and relatively low power motors. High carbon steel bandsaw blades are often known as “Standard Blades”. Standard blades are best described as general purpose and are fit for all those normal tasks in the workshop where a smooth, good quality, ‘no fuss’ performance is required, day in and day out.
Ground Tooth Bandsaw Blades
Our “Standard Blades” are nothing but standard, the unique Ground Tooth (GT) design. This newly developed material is designed for the production user with high feed rates of cutting and is ideally suited to the rigours of running on two wheels. The diamond ground teeth are so unbelievably sharp (they stay sharper for at least 30% longer) that the blades work extremely well in all materials giving an exceptionally high quality finish and clean cut. The GT range is designed for general purpose board and cross grain cutting work.
Discover the merits of the GT Bandsaw blades in our in depth blog.
Freshcut 37 GT
Its sister range for rip cutting is the Freshcut 37. The teeth are precisely diamond ground, before going through a hardening process, then annealed for flexibility and finally the stock straightened by a machine process. This produces a super sharp, hard tooth, with the benefits of a long cutting life and a smooth, quiet cut. The teeth have a light set which gives a narrow kerf and reduces the waste produced whilst the hook configuration provides maximum penetration. These blades are perfect for ripping all types of timber, producing veneers and boards, the ground teeth retaining their edge far longer than normal milled tooth blades - a unique bandsaw concept.
If you hit the occasional nail with your bandsaw blade, it invariably happens just after installing a new one! No longer a problem with these Premium Bandsaw blades! They use M42 High Speed Steel with 8% cobalt which has been welded to a spring alloy steel backing. This results in a material that has a far greater resistance to heat and abrasion, therefore giving improved cutting performance in those materials that might have proved troublesome with a Standard blade. All types of material can be cut with ease, including abrasive timbers such as teak as well as man-made boards like MDF and chipboard, where the glue used has little, if any effect on the life of the blade. M42 blades are so resilient that reclaimed timber presents no difficulties, as the blade will slice easily through the odd nail buried under the surface.
Back Tooth Bandsaw Blades
For woodturners, we have a unique blade concept, the Back Tooth bandsaw blade. Woodturners often prepare their own blanks, which is where the back tooth blade becomes particularly useful, as it has been specifically developed for curvature cutting. The teeth on the rear of the blade are not sharp to handle but have the effect of clearing the back of the cut by widening the kerf, enabling a much tighter curve to be cut making them an ideal choice for preparing timber for the lathe. Available only in 8mm 4 tpi configuration which is suitable for almost all machines.
Ripper 37
For deep rip cutting work we offer the Ripper 37 blade. Specifically intended for wood processing and deep ripping tasks, fitting only a few larger machines where motors of sufficient capacity are able to handle the 32mm wide blade. The teeth are precision ground using CNC machinery and then induction hardened. Furthermore, to ensure a very long working life, each blade can be re-sharpened up to twenty times, offering the best possible cutting performance.
Where are Axcaliber bandsaw blades made?
The answer is, right here in Axminster. All Axcaliber blades are made from UK sourced stock, sized, welded, finished and packed in our own engineering production facility in Axminster. Carefully chosen production techniques and constant quality control checks ensure each blade will exceed your expectations. And if the weld breaks under normal use, we will replace the blade, no quibbles.
Learn how Axcaliber bandsaw blades are produced and manufactured with Axminster Expert Craig Steel.
