Before You Start - Woodworking
Before you start woodworking, small decisions make a big difference. Learn six simple principles to improve accuracy, avoid common mistakes, and build with confidence.
Principle 1: Accuracy starts before the first cut
Before you start cutting…
Most woodworking mistakes don’t come from a lack of skill. They come from tools that are slightly out of alignment before the first cut is ever made.
- A fence that’s a millimetre out.
- A blade that isn’t quite square.
- A guide that’s drifted over time.
None of these look serious on their own - but together, they compound. That’s when joints don’t close and projects feel frustrating for reasons that are hard to explain. Before you start your next project, take a few minutes to check that your reference points are truly square.
One helpful tool: An engineer’s square gives you a reliable reference you can trust. You don’t use it often - but when accuracy matters, it removes doubt. You’re not doing anything wrong. You’re just setting yourself up to succeed.
Principle 2: Measure to mark - not to cut
A quiet habit that changes everything
Most experienced woodworkers don’t cut from a tape measure. They cut from a line. The tape gets you close - the mark gives you accuracy. Pencil lines are quick, but they’re thick and imprecise. When joints need to meet cleanly, that small ambiguity matters more than we think.
Before you start cutting, slow the process slightly:
- Measure carefully
- Mark deliberately
- Cut to the line
One helpful tool: A marking knife creates a fine, unmistakable line and gives your saw or chisel a physical reference to follow. It’s not about being fussy - it’s about removing guesswork.
Principle 3: Wood moves (whether we plan for it, or not)
Why wood behaves differently across the year
Wood is never static. It expands, contracts, and responds to humidity long after the tree has been milled. Projects that crack, bind, or warp often fail not because they were badly made - but because movement wasn’t allowed for.
Before you start any build, pause and consider:
- Where will this piece live?
- How might the seasons affect it?
- Does this joint allow the wood to move naturally?
One helpful tool: A moisture meter removes the mystery and lets you work with confidence instead of assumption. Understanding wood doesn’t overcomplicate things - it simplifies them.
Principle 4: Sharp tools are safer tools
Pushing harder isn’t the answer
When a tool stops cutting cleanly, our instinct is to push harder. That’s when control is lost.
Sharp tools:
- Cut with less effort
- Leave cleaner surfaces
- Reduce slips and mistakes
Before you start, check your edges. If the tool feels like it’s making you work too hard, it’s telling you something.
One helpful tool: A simple sharpening stone or honing guide makes maintaining an edge straightforward - no expertise required. Sharp tools don’t make you faster. They make you calmer.
Principle 5: A dry assemble can save a project
Glue won’t fix what doesn’t fit
Glue is permanent - but it shouldn’t be a surprise.
A dry fit shows you:
- Where joints are tight or stressed
- Whether alignment holds under pressure
- How the assembly feels as a whole
Before you open the glue bottle, assemble everything once without it.
One helpful tool: Parallel clamps apply even pressure and keep assemblies square during test fits. A calm dry fit often means a calm glue‑up.
Principle 6: Start with reference faces
One simple habit that prevents compounding errors
Perfect measurements don’t help if they’re taken from inconsistent faces.
Every project improves when you choose:
- One face side
- One face edge
…and reference all measurements from them.
Before you start cutting parts, decide what those reference surfaces are and mark them clearly.
One helpful tool: A marking gauge lets you transfer consistent measurements without re‑measuring every time. Consistency beats perfection.
Final thoughts...
Woodworking rarely goes wrong in one obvious moment. More often, small inaccuracies build quietly until they show up later in the project. Taking a little time before you start woodworking - to check your setup, understand your material, sharpen your tools, and work from consistent references - doesn’t slow you down. It makes everything that follows smoother, more predictable, and far more rewarding.
These principles aren’t about perfection or experience. They’re about awareness. Whether you’re just getting started or refining your approach after years in the workshop, returning to these basics can make a noticeable difference. Not just in the results you achieve, but in how the work feels while you’re doing it.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our blogs?
