A Diamond upgrade for flawless Tormek Sharpening
Diamonds are forever: Give your Tormek Sharpening System the ultimate upgrade
If you already own a Tormek T-8 or Tormek T-4 sharpening machine, you’ve already invested in precision. Now it’s time to unlock its full brilliance with an upgrade that’s as enduring as it is effective. Enter Tormek Diamond Wheels, the ultimate accessory for sharpeners who want edges that last, results that sparkle, and performance that truly shines. Just like a perfectly cut diamond, these wheels are engineered to stay true, resist wear, and deliver consistent results. They’re a cut above the rest, quite literally.
Why choose Tormek Diamond Wheels?
Diamond is the hardest known material, making it the ideal abrasive for sharpening steel, ceramic, and carbide tools. Unlike traditional grindstones, Tormek Diamond Wheels give you no hollowing, dishing, or grooving, no dressing required, sharpening on both the periphery and the flat side, and perfectly flat bevels when paired with the MB-100 Multi Base. Whether you’re restoring a battered chisel or refining a delicate carving knife, these wheels make your Tormek system more versatile, efficient, and precise.
Flawless cuts, minimal effort
A diamond’s beauty lies in its ability to hold its shape - and so do these wheels. They maintain their form and grit for years, so your tools stay razor-sharp without extra fuss. That means no grinding pressure, no stone truing, no stone grader, and ultra-easy operation. A small investment now means a lifetime of flawless edges.
Available in three brilliant cuts (grits!)
Diamond Wheel Coarse (360 grit) – Rapidly repairs dull or damaged edges. Perfect for grinding and reshaping.
Diamond Wheel Fine (600 grit) – The versatile all-rounder, removing steel efficiently while leaving a smooth finish.
Diamond Wheel Extra Fine (1200 grit) – Leaves an ultra-smooth finish, ideal for carving tools and knives with minimal steel removal.
Remember – size matters!
200mm Diamond Wheels are for Tormek T-4 Original, Tormek T-4 Bushcraft, Tormek T-3, and earlier 200mm models. 250mm Diamond Wheels are for the Tormek T-8 sharpening system.
Complete the set with the MB-100 Multi Base
Want to unlock the full sparkle of your new diamond wheels? Add the MB-100 Multi Base. Designed for side sharpening, it allows you to create completely flat bevels, perfect for chisels, plane irons, and other fine-edge tools. It also converts the horizontal mounts to vertical, for easier access when knife-edge trailing and for guided honing using knife jigs. It’s the final facet that makes your Tormek setup truly complete.
An investment that shines for a lifetime
When it comes to sharpening, consistency is everything, and Tormek Diamond Wheels deliver it brilliantly. With unmatched durability, effortless operation, and flawless results, they’re not just an accessory – they’re an investment in your tools, your time and your craft.
Diamonds are forever, and with these wheels, so is your edge!
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our other blogs?
Get in touch!
If you’ve used a Tormek sharpening machine for one of your projects, or have recently bought one, we'd love to hear from you. Send us a photograph and tell us all about what you've been up to, or what you've bought.
Alternatively, get in touch via our social media platforms. Find us on Facebook or Instagram.
Email updates
Not part of our Email Updates yet? Sign up for FREE to receive exclusive offers, new product launches and woodworking content tailored to your individual likes and interests.
Tormek DC-200 Diamond Wheel Coarse - 200mm
Tormek DC-250 Diamond Wheel Coarse - 250mm
Tormek DF-200 Diamond Wheel Fine - 200mm
Tormek DF-250 Diamond Wheel Fine - 250mm
Tormek DE-200 Diamond Wheel Extra Fine - 200mm
Tormek DE-250 Diamond Wheel Extra Fine - 250mm
Tormek MB-102 Multi Base
