Festive Projects | Christmas Sleigh and Reindeer
Festive Projects
In this article, learn how to make your own Christmas sleigh and reindeer. Watch our video or follow our step by step guide below.
Sleigh
Step 1
Prep your material. To get the piece of timber required for this project we laminated two bits of wood together to get a block of wood measuring 128 x 255 x 140mm (H x L x W).
Step 2
Draw out your template on block of timber.
Step 3
Cut out template on bandsaw (you can do this by hand using handsaw and coping saws).
Step 4
Once the main shape has been cut out you will then need to cut two side pieces away from the block of timber. Using the bandsaw fence cut a 25mm piece off either side of the sleigh. Set these aside for later.
Step 5
On the remaining block of timber mark up the waste material that you will cut out for the middle of the sleigh. Then cut it out.
Step 6
Cut off the bottom sled section of the sleigh and discard this waste material.
Step 7
Using a sanding power tool or just sanding paper. Sand out any machinery marks on all pieces of the sleigh.
Step 8
Glue up the main body section of the sleigh with the sleigh side panels. Clamp and leave to dry.
Step 9
Once the glue is dry, sand the sleigh again rounding off any sharp corners.
Step 10
Apply your finish of choice. You can paint it or leave it natural with a nice finishing oil, lacquer or wax
Reindeer
Step 1
Glue your reindeer template to your chosen timber. Using a PVA glue or Copy Dex glue this makes it easy to remove the template once you have finished cutting it out.
Step 2
Cut out your template on the scroll saw.
Step 3
Remove the template from your project and assemble.
Step 4
Finish the reindeer using your finish of choice. You could even paint the reindeer with colours.
Troubleshooting – This reindeer template slots together, therefore the thickness of your material may change how wide the slots need to be to make sure it all fits together.
Final thoughts...
These festive projects are all about creativity and craftsmanship – from building a charming Christmas sleigh to crafting elegant reindeer. Whether you’re making unique gifts or eye-catching decorations, the right tools will help you achieve professional results with ease. With precision cutting, dust-free sanding, and reliable performance, our featured products are here to inspire your next festive masterpiece. So, gather your materials, follow the steps, and let your imagination bring the season to life!
Email Updates
Not part of our Email Updates yet? Sign up for FREE to receive exclusive offers, new product launches and woodworking content tailored to your individual likes and interests.
Discover more...
Finally, if you've enjoyed reading this guide, why not take a look at some of our blogs.
Made it? Share it!
If you have made this project or any of our Woodworking Wisdom projects we would love to see them. Share with us your pictures on social media by searching and tagging @axminstertools on Facebook or Instagram.
