Woodworking Wisdom
How to Make a Bridle Joint
In this article we explore how to make a bridle joint, which is a woodworking joint used mostly for framing.
A bridle joint is a type of mortice and tenon and is also called an open tenon, or tongue and fork joint, due to how the timber sections slot together.
The interlocking sections provide great stability and make this joint a strong and versatile choice. It is most commonly used in creating frames, particularly where rails and legs join. It is a great choice for workbench construction also.
Learn how to cut a bridle joint
Watch our Woodworking Wisdom demonstration with fine furniture maker, Sean Evelegh, as he shows you how to hand cut a bridle joint.
Other cabinet joints
Read our other articles to learn how to make a range of furniture and cabinet joints and perfect your joinery skills.
Leave a comment
