Woodworking Wisdom
How To Make A Coat Hook Rack
Woodworking DIY Projects
Step 1
Run board through a planer to make the faces flat. A hand plane can be used for this.
Planing the wood
Marking the peg line
Step 2
Use a pencil and a rule to mark out your line of pegs.
Step 3
Mark out the spacing between each peg.
Marking the space between pegs
Step 4
Use an awl to mark for drilling. Or, alternatively, position metal hooks.
Marking with an awl
Positioning metal hooks
Step 5
Sand face to remove pencil marks.
Sanding to remove pencil marks
Step 6
Using a power drill, drill bit and a drill guide, drill holes for pegs. We have used a 12mm lip and spur bit, but this will depend on the size of peg you want.
Set drill guide at the angle you want your pegs to be.
Drill guide at an angle
Drilling the peg holes
Marking fixing holes
Step 7
Mark and drill two fixing holes. These should be equally spaced either side.
Step 8
Set the drill guide to 90 degrees and drill to a depth of 10mm. We used an 8mm drill bit.
Drilling fixing holes
Drilled fixing holes
Scribe a radiusv
Step 9
Using a plate, or something similar, scribe a radius at both ends of the board.
Step 10
Cut the marked radius using a jigsaw or a bandsaw.
Cutting the radius using a jigsaw
Cutting the radius using a bandsaw
Step 11
Using either a disc sander or a sanding block, sand down radius.
Step 12
Strip off any bark from the board. Using a wire brass brush clean off any debris.
how_to_make_a_coat_rack_strip_off_bark
Scratch debris
Step 13
Peg turning. Rough down 25mm yew.
Rough down peg
Step 14
Using some spring calipers, measure the drill bit you used to create the peg holes and turn your tenon to fit.
Measure drill bit with spring callipers
Step 15
Shape your peg.
Shape peg
Step 17
Sand away any excess timber.
Sand peg
Sand excess timber
Turned peg
Tapping the pegs in
Step 18
The pegs should be tight enough to just tap in using a nylon or wooden mallet.
Step 19
Turn plugs to cover fixing holes.
Turned hole plug
Step 20
Hang and use coat hook.
How to make a coat hook rack
Leave a comment
