Woodworking Wisdom
Metalworking Lathe Accessories | What To Buy Next For Your Lathe
Metalworking lathe accessories
A metalworking lathe is one of the most versatile machines in any engineering workshop, capable of producing precision components, threaded parts, custom fittings and repair pieces. But once you’ve invested in your lathe, you’ll soon discover that the right accessories can dramatically improve accuracy, efficiency and the range of projects you can undertake.
Whether you’re a hobby machinist setting up your first workshop or an experienced engineer looking to expand your capabilities, these are some of the metalworking lathe accessories worth considering next.
A lathe is only one part of the machining process. From securely holding materials to achieving precise measurements and superior finishes, accessories help you work more safely, accurately and confidently. Read our helpful guide to discover some of the most useful accessories to add to your metalworking lathe setup.
Shop all metal lathe accessories
Metal lathe chucks and jaws
A high-quality lathe chuck is one of the most important accessories for any metalworking lathe. While many lathes come supplied with a standard three-jaw self-centring chuck, expanding your work-holding options can significantly increase the versatility of your machine. Different chuck and jaw configurations allow you to securely hold a wider range of materials, shapes and workpiece sizes.
Ideal for:
  • General turning operations
  • Bar stock machining
  • Irregular workpieces
  • Precision engineering projects
Consider adding:
  • Four-jaw independent chucks
  • Collet chuck systems
  • Soft jaws
  • Extra hard jaw sets
  • Faceplate clamps
A versatile work-holding setup allows you to tackle more complex machining tasks with greater accuracy and confidence.
Lathe tooling, tool holders and cutting tools
No metalworking lathe setup is complete without a range of quality lathe tooling, tool holders and cutting tools. Whilst basic tooling may be sufficient for general turning, specialist tools can improve productivity and surface finish while expanding the range of machining operations you can perform.
Ideal for:
  • Improved cutting performance
  • Better surface finishes
  • Increased machining efficiency
  • Precision work
Popular additions include:
  • Indexable turning tools
  • Parting tools
  • Boring bars
  • Threading tools
  • Knurling tools
  • Quick-change tool holders
Having the right cutting tool for the job often reduces machining time while delivering more accurate and consistent results.
Shop tooling
Collet systems and collet holders
For smaller workpieces and high-precision machining, collet systems offer excellent concentricity and gripping power. They provide a more accurate alternative to standard chucking methods and are particularly useful when working with bar stock.
Ideal for:
  • Small diameter materials
  • Precision turning
  • Production work
  • Repetitive operations
ER collet systems are particularly popular due to their versatility and ability to accommodate a wide range of material sizes.
Shop collet holders
Revolving and dead centres
A quality revolving centre is an essential accessory when machining long workpieces between centres. It provides additional support, reducing vibration and helping maintain accuracy throughout the turning operation.
Ideal for:
  • Shaft production
  • Long workpieces
  • Precision turning
  • Heavy cutting operations
Modern revolving centres feature improved bearings and interchangeable points for different machining applications.
Shop revolving and dead centres
Tool posts, tool rests and steadies
Work-holding and tool support accessories play a vital role in achieving accurate, consistent machining results. Many machinists consider a quick-change tool post one of the most worthwhile upgrades available for a metalworking lathe, allowing cutting tools to be swapped quickly whilst maintaining precise centre height settings. Tool rests provide additional support for hand-held cutting tools during specialist operations, while fixed and travelling steadies help support long or slender workpieces, reducing vibration and improving machining accuracy.
Ideal for:
  • Faster setup times
  • Improved repeatability
  • Multi-tool operations
  • Supporting long workpieces
  • Reducing vibration and deflection
  • Greater workshop efficiency
Additional tool holders can be kept permanently set up for commonly used tools, helping reduce downtime between operations. Meanwhile, steadies can significantly improve the accuracy of shaft work and other longer components by providing extra support during machining.
Shop tool rests and steadies
Measuring and inspection equipment
Precision measurement is at the heart of metalworking. Accurate measuring equipment helps ensure components are machined to the correct dimensions and tolerances.
Ideal for:
  • Dimensional accuracy
  • Quality control
  • Repeatable results
Essential additions include:
Investing in reliable measuring equipment is just as important as investing in quality machining equipment.
Shop measuring and inspection equipment
Metal lathe slides
Many metalworkers choose accessories that expand the capabilities of their lathe. Milling slides, vertical slides and drilling attachments can increase workshop versatility without requiring additional floor space.
Ideal for:
  • Drilling operations
  • Milling small components
  • Slot cutting
These accessories allow certain machining operations to be completed on the lathe, making them particularly popular with home workshop users.
Shop metal lathe slides
Coolant systems and cutting fluids
Proper cooling and lubrication play an important role in extending tool life and improving machining performance. Coolant systems help manage heat while improving chip evacuation and surface finish.
Ideal for:
  • Prolonging tool life
  • Improved finishes
  • Heavy machining
  • Difficult materials
Popular options include cutting oils, coolant pumps and magnetic coolant hose systems. Looking for a drip tray or splash guard? Take a look here.
Shop coolant systems and cutting fluids
Work lights and magnification
Good visibility is essential for precision machining. Dedicated machine lighting and magnification accessories help improve accuracy while reducing eye strain during detailed work.
Ideal for:
  • Fine machining
  • Inspection work
  • Improved visibility
  • Small component production
Many machinists are surprised by how much easier precision work becomes simply by improving lighting around the machine.
Shop work lights and magnification
Chip management and workshop cleanliness
Metalworking generates swarf, chips and cutting fluid residue that can quickly accumulate around machinery. Accessories that help manage waste improve both safety and workshop organisation.
Ideal for:
  • Cleaner workshops
  • Improved safety
  • Easier maintenance
  • Better workflow
Popular solutions include swarf trays, chip brushes, magnetic collectors and workshop vacuums designed for metalworking environments.
Health and safety equipment
Safety should always remain a priority when operating a metalworking lathe. Appropriate protective equipment helps minimise risks whilst providing greater confidence during machining operations.
Ideal for:
  • Eye protection
  • Face protection
  • Workshop safety
  • Safe machining practice
Consider essential safety equipment such as safety glasses, face shields, hearing protection and suitable workshop clothing.
Shop health and safety equipment
Final thoughts...
A metalworking lathe becomes significantly more capable when paired with the right accessories. For most machinists, investing first in quality work-holding solutions, cutting tools and accurate measuring equipment will deliver the greatest immediate benefits. From there, accessories such as quick-change tool posts, collet systems, coolant equipment and specialist tooling can further improve productivity and machining accuracy.
Whether you're producing precision components, repairing machinery, making model engineering parts or undertaking general workshop projects, the right metalworking lathe accessories will help you machine more accurately, work more efficiently and get the best possible results from your lathe. Explore our range of metalworking lathe accessories and discover what's possible with your machine.
Email updates
Not part of our Email Updates yet? Sign up for FREE to receive exclusive offers, new product launches and woodworking content tailored to your individual likes and interests.
Subscribe now, don't miss out!
Discover more...
Finally, if you've enjoyed reading this guide, why not take a look at some of our blogs?
Get in touch!
Get in touch via our social media platforms. Find us on Facebook or Instagram.
Leave a comment
