Revolutionise Your Woodcarving With Arbortech's Newest Addition
Introducing the Arbortech Ball Gouge
The cleverly engineered, woodworking attachment that's revolutionising the way you carve!
The Arbortech Ball Gouge is a spherical shape attachment that will fit most standard grinders. It allows you to free form, gain access, and have greater control over your woodworking projects! Let’s have a look at a few reasons why this tool is THE most efficient tool of its calibre.
Versatility
The Ball Gouge gives you the ability to achieve a variety of shapes and textures in your woodwork.
- Smooth concave surfaces in spoons and small bowls
- Hollow out and undercut
- Freehand sculpting and chisel texture
- Chiseled texture on wooden surfaces
- Carve in any direction without compromising on control
Control
With an aim to provide you with exceptional control and balance in your woodwork, Arbortech used their ‘clever engineering’ to design an anti-grab technology. This innovative technology prevents the tool from digging and grabbing into the wood and allows you to freely hollow out concave surfaces to achieve a finish and look you desire.
Performance
The Arbortech Ball Gouge fits most standard 110mm & 115mm angle grinders and handles speeds up to 12,000 RPM. The tool also has a ring shaped blade that is self-sharpening, rotatable and replaceable. Not only is the tool long lasting, its high performance makes it the most efficient tool of its calibre.
This unique addition to the Arbortech range demonstrates perfectly what their ‘clever engineering’ can produce. The Arbortech Ball Gouge enables you to have control and balance over your woodworking projects, where you can explore a variety of finishes with a tool that is specifically designed to last!
Discover more from Arbortech with their plans and tutorials in power carving.
