Power Carving | Arbortech Power Carving Tools
Unleash Your Creativity with Arbortech Power Carving Tools
In this blog, we'll explore the various Arbortech power carving tools and how they can elevate your woodworking projects.
Arbortech Power Carving Unit MKii
The Arbortech Power Carving Unit MKii is the cornerstone of their power carving range. This versatile tool is designed to work with a variety of Arbortech attachments, making it perfect for a wide range of carving tasks. Whether you're shaping, sanding, or detailing, the Power Carving Unit provides the power and precision you need to achieve professional results.
Arbortech SpheroPlane
The Arbortech SpheroPlane is a precision carving attachment that allows you to create smooth, rounded surfaces with ease. It features an adjustable carving radius and patented cutting action, making it perfect for detailed work. The SpheroPlane also includes dust and chip extraction, reducing mess and making clean-up easier.
Arbortech TURBO Plane Blade
The TURBO Plane Blade is one of Arbortech's most popular attachments. This tungsten carbide woodcarving disc is perfect for rapid shaping and sculpting. It can be used to create flat surfaces, concave shapes, and even intricate details. The TURBO Plane Blade's unique design allows for smooth and controlled cuts, making it a favourite among woodcarvers.
Arbortech Ball Gouge
The Arbortech Ball Gouge is another innovative attachment from Arbortech. This spherical-shaped milling ball is ideal for free-form carving and hollowing. It can be used to create smooth, concave surfaces and is perfect for sculpting small to medium-sized projects. The Ball Gouge's unique design ensures a smooth and even cutting experience.
Arbortech Contour Sander
The Arbortech Contour Sander is a revolutionary attachment designed for detail sanding of deep profiles and contours in woodworking projects. It is perfect for achieving a smooth finish on intricate designs and hard-to-reach areas. The Contour Sander can be attached to most standard 100mm (4") or 115mm (4.5") grinders, providing excellent control and precision for detailed sanding tasks.
Precision Carving System
The Arbortech Precision Carving System is a comprehensive kit designed for free-form carving, sculpting, detailing, and texturing. It includes a Universal Base that fits the Arbortech Power Carving Unit or a 100mm (4") or 115mm (4.5") angle grinder. The system comes with three interchangeable precision attachments: the Precision Ball Gouge for carving tight radii, the Precision Barrel Carver for controlled carving in tight spots, and the Precision Drum Sander for finishing and polishing.
Arbortech Mini Products
Arbortech Mini Carver MKii
The Arbortech Mini Carver MKii is a compact and powerful tool designed for detailed carving and sanding. It comes with a range of attachments, including a sanding pad and a chip catcher, making it perfect for intricate projects. The Mini Carver's adjustable speed settings allow you to control the tool's performance, ensuring precise and accurate results.
Arbortech Mini TURBO™ Plane Kit
The Arbortech Mini TURBO™ Plane Kit is designed to fit the Arbortech Mini-Grinder Carver™ and most 100mm or 115mm angle grinders using the supplied extension adaptor. This unique tool is perfect for freehand carving, allowing you to create smooth, concave, and convex shapes with ease. The kit includes the Mini TURBO™ blade, extension adaptor, brass M10 – M14 threaded adaptor, three assorted sanding discs, a rubber backing pad, M5 fixing screws and washers, plus torx and hex drive keys.
Arbortech Mini Pro
The Arbortech Mini Pro is a hybrid of the Mini TURBO™ and the Mini Industrial Blade™. It is a small 50mm blade with large and uniform cutting teeth that cut on the periphery, making it the smoothest small blade in the Power Carving Range. The Mini Pro is specifically designed for the Mini Carver™ but is also compatible with the Mini Grinder™. It excels in smooth freehand shaping and texturing, providing both rapid wood removal and precision for detailed work.
Conclusion
Arbortech's range of power carving tools offers something for every woodcarver, from rapid shaping to intricate detailing. With their innovative designs and high-quality construction, Arbortech tools can help you take your woodworking projects to the next level. Explore the full range of Arbortech power carving tools and unleash your creativity today!
Arbortech Power Carving Unit MKII
Arbortech Mini Carver MKII
Arbortech Mini TURBO Plane Kit
Arbortech Mini Pro
