Love your Lungs | Our Top Respirators For Enhanced Safety and Comfort
Whilst wearing the correct respirator is essential, you should implement other safety measures for maximised protection during your woodworking activities. Remember to allow for adequate ventilation, use a dust extraction where applicable and maintain a clean working environment to minimise dust exposure.
Our top respirators
Providing protection of FFP3, this respirator is specifically designed to shield you against fine dust that can be hazardous to breathe in. Activities such as sanding, routing or any sawing or cutting can produce harmful airborne sawdust and wood chips, so it is essential you safeguard your lung health. Adjustable and comfortable, the endoskeleton structure of this mask results in an unrivalled, snug fit.
"The best and most comfortable mask I've worn yet.. really first class"
Axminster Tools customer
Featuring the Typhoon valve, this respirator reduces breathing resistance, heat and moisture build up. Being unaffected by any moisture this FFP2 mask can be used with the same performance under very low temperatures as well. The foam strip around the inside of the mask adds to the comfortability and performance. A better fitting mask is imperative to offering maximised protection. Whilst offering a lower level of protection than FFP3, FFP2 masks are still an effective option when breathing in larger dust particles.
"This is an excellent and comfortable dust mask. Easy to fit and adjust and can be worn for the whole day no problem"
With two PressToCheck P3 high-efficiency particulate dust filters, this capable half-mask allows you to check that you have the correct seal every time. The Force ™ 8 features the Typhoon™ valve, which has very low breathing resistance, allowing you to breathe comfortably without fatigue. Use for a wide range of uses, providing filtering protection against many gases and vapours. Reuseable, easily cleaned, and maintained. Lasts far longer than single-use disposable masks and is extremely comfortable.
"A really nice piece of kit. It’s a very nice fit on the face and head, the mask is very comfortable and it filters without restrictions on breathing"
The Scan Reusable Half Mask Respirator is a practical, reusable option for protecting against dust, fumes, vapours and gases, offering a secure seal over the nose and mouth for improved safety in the workshop. Designed with comfort in mind, it features a soft silicone facepiece, adjustable straps and an exhalation valve to make breathing easier during longer tasks. Its bayonet connection allows you to pair it with a range of compatible filters depending on the job, making it a flexible alternative to disposable masks (note: filters are sold separately).
The JSP Powercap Powered Respirator with Impact Visor is a lightweight, all-in-one protective head unit designed for dusty work environments, combining respiratory, eye/face, and head protection in a single system. It uses a battery-powered motor to deliver a constant flow of filtered air (around 160 L/min), creating positive pressure that makes breathing easier, reduces fatigue, and helps prevent visor fogging. The impact-resistant visor provides protection from flying debris, while the built-in bump cap adds light head protection, and the rechargeable battery offers up to around 8 hours of runtime. Rated to EN12941 TH1P (APF 10), it provides reliable protection against dust and airborne particles, making it a comfortable and practical alternative to traditional face masks for extended use.
Offering high levels of protection against multiple hazards, this respirator combines TH3 respiratory protection, along with eye, face, and head protection. With the option of adding Sonis ear defenders for hearing protection. Powerful yet lightweight, the battery-powered fan draws the air through the filters to blow clean air down over your face. Delivering 160 litres of clean air a minute, you can breathe freely with this hugely capable powered respirator.
Offering an excellent fit, this lightweight full-face mask offers a comfortable and easily maintained. This is a great option for aiding breathing in dusty environments. The optical Class 1 visor conforms to EN166.B impact protection. The completely clear panoramic visor maximises light levels within the mask for optimum visibility. Easily adjusting to most face shapes, the PressToCheck filters ensures that you have the correct seal every time. Adaptable, protecting you against particulates, many gases and vapours.
"My lungs have never felt so safe."
If you enjoyed this blog, you might be interested in reading our others.
Read Dust Extractors | A Spotlight on All Things Power Tool Extraction or How To Choose Your Next Power Tool Dust Extractor - Woodworking Wisdom .
JSP SpringFit™ Fold Flat Valved Respirator FFP3 (Pkt 10)
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)
JSP Force™ 8 Reusable Half Mask Complete Medium P3
JSP APF40 PowerCap® Infinity® Powered Respirator TH3
JSP Force™10 Typhoon™ Full Face Mask With Visor
