A small and simple project to get you started with resin. This small bowl, made using epoxy resin and hazel twig discs, is a great starter project ...
Latest posts
If you have ever wanted to try eccentric woodturning, then this is the project for you. But first you will need an eccentric spiralling chuck.With ...
Knowing your headstock from your tailstockA vital accessory for the woodturning lathe, for any turner, is the humble woodturning lathe centre. Used...
There are many tool rests available on the market from solid, traditional, cast iron rests, to modern, lighter and stronger designs. But here at Ax...
Which handle to use?Choose the smaller handle when working with workbench lathes and small turning projects, such as bowls; or the larger handle fo...
You’ve just bought your lathe, but are unsure what turning tools you need? Relax, woodturning expert, Colwin Way, takes you through the Axminster C...
