Buying a compressor can be confusing. This is guide will go through the key factors and considerations so you can make an informed decision, first ...
Latest posts
A buyer's guide to the Bosch Flexiclick drills, the GSR 12V-15 FC and GSR 18 V-EC FC2. An explanation of the attachments and a comparison of the te...
Mirka DEOS a new orbital sander with an 81 x 133mm pad, 3mm orbit and vibration monitoring. Here's an indepth look at all the new features.
With a wide range of abrasives available, it can be quite hard for you to pick the one you need. Here we take a look at all of the Hermes abrasives...
The UJK Technology Otoro Palm Router Table helps you significantly increase the versatility of a palm router. Master decorative mouldings, edge pre...
Introducing two new metal cutting bandsaws to the Axminster Engineer Series range. Both with the versatility to perform in a number of different se...
