The Leigh B975 Box Joint and Beehive Jig provides fast and accurate routing of classic box joints. Simply guide your router around the 1/2" comb or...
Latest posts
If your project involves joining two pieces of wood together, Pocket Hole Jigs tick all the boxes. Once you realise how fast, strong, and simple po...
Woodworking Workshops - A Step Closer To Achieving The DreamTools and machinery to considerDepending on whether you’re an apprentice, hobbyist or p...
Top Tools That Every Cabinet Maker Should Consider Owning...JigsawWith the right blade you can cut intricate shapes and make compound and bevel cut...
There isn’t much call these days in the normal run of events to use an old fashioned, steel, countersunk screw, let alone brass screws, so much so ...
In my recent article about Precision rulers, I spent some time extolling the virtues of decent rules in the workshop and the same sentiments can be...
