Woodworking Wisdom
Beginner’s Guide to MFT-Style worktops | UJK Parf MkII Guide System
A Beginners Guide to MFT
What can you do with a Parf / MFT-Style worktop?
The answer: a lot more than you might think. An MFT-style worktop, especially one created with the UJK Parf MkII Guide System, is far more than just for power tools. We've broken down some of its most versatile uses to show just how much functionality it can bring to your workshop:
What can you do with an MFT-style worktop_ 01
What can you do with an MFT-style worktop_ 02
What can you do with an MFT-style worktop_ 03
Consistency
An MFT-style worktop with a precision-drilled grid ensures repeatable accuracy, maintaining consistency in cutting and routing when used with a guide rail, delivering absolute precision every time.
Clamping
The 20mm hole pattern created by the Parf MkII Guide System allows for flexible, secure clamping anywhere on the grid, making it easy to stabilise workpieces without bulky vices or custom jigs. Use the UJK MFT Horizontal Quick Clamps anywhere on the grid to hold your work fast, exactly where you need them, without getting in the way.
Awkward Work Holding
Irregular or curved components can be safely held using UJK Guide Dogs and UJK Cam Clamps and wedges, providing better control for sanding, routing, or shaping.
45/90° Angles
UJK Super dogs, UJK Guide Dogs, guide rails, and the grid layout make it simple to align tools and workpieces at perfect 45° and 90° angles, ideal for parallel, square and mitre cuts, joints, and accurate layouts.
Assembly
The UJK Parf MkII guide Systems creates a precise grid layout, making it easy to align, square, and clamp components for assembly, ideal for everything from cabinets to small box projects.
Sheet work
Large sheets of wood are easily supported on the bench while accurately cutting or routing, preventing flex and reducing the risk of tear-out or error.
Parf set up made simple!
Setting up the UJK Parf Guide System is easy. You can create a fully customised MFT-style workbench to suit you and your needs, even in the smallest of workshops, in 30 minutes or less.
Setup 01
Setup 02
Setup 03
So, how do you make it?
Don’t just take our word for it!
The UJK Parf MkII guide system has over 500 reviews from woodworkers from all walks of woodworking! As well as some known faces of Radha Sivyer and Badger Workshop!
A wonderfully well thought out system with clear instructions and plenty of video tutorials."
Super simple to use, incredibly accurate!”
The system is easy to set up and adjust, making it suitable for both professional and hobbyist woodworkers.”
I have never had an MFT style bench top before - let alone made one - but the Parfguide system made the process easy and painless.”
Been deliberating to purchase this or replacement tables... wow awesome piece of kit.”
I don’t have a workshop, so used this to create a 600 x 600 worktop to fit on my Black and Decker workmate. Excellent results using track saw and hand tools.”
Let’s see the UJK Parf MkII Guide System in action:
Parf isn’t a dark art, it’s just clever engineering
Precision by design 05
Precision by design 04
Precision by design 03
With the UJK Parf MkII Guide System, you don’t need years of experience or a full-scale workshop. It’s about working easier, faster, smarter. So why not take the guesswork out of perfect cuts and reliable setups? Explore the Parf MkII Guide System and start building with confidence.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our other blogs?
Leave a comment
