Woodworking Wisdom
Woodworking Clamps - Overview
Woodworking clamps
Woodworking Clamps
At Axminster Tools, we stock a wide range of different types of clamps. Click on the headings below to find out more!
F Clamps
F Clamps
F Clamps, also known as bar clamps, are versatile and adjustable, making them ideal for a wide range of woodworking tasks. They consist of a long metal bar with adjustable jaws that can be tightened to hold workpieces securely.
Explore F Clamps
G Clamps
G Clamps
G Clamps, or C Clamps, are robust and provide a strong clamping force. They are perfect for heavy-duty tasks where a firm grip is required. Their simple design makes them easy to use and highly reliable.
Explore G Clamps
C Clamps
C Clamps
C Clamps are similar to G Clamps but are typically smaller and used for lighter tasks. They are great for holding small workpieces or for use in tight spaces where larger clamps wouldn't fit.
Explore C Clamps
One Handed Bar Clamps
Next, one Handed Bar Clamps are designed for convenience, allowing you to clamp and release with one hand. This makes them perfect for quick adjustments and tasks where you need to hold the workpiece with the other hand.
Explore One Handed Bar Clamps
Sash Clamps
Sash Clamps
Sash Clamps are long and sturdy, making them ideal for large-scale projects such as door frames and window sashes. They provide a strong and even pressure across the entire length of the workpiece.
Explore Sash Clamps
Parallel Clamps
Parallel Clamps
Parallel Clamps provide even pressure along the entire length of the clamp, making them ideal for tasks that require precise alignment, such as panel glue-ups.
Explore Parallel Clamps
Spring Clamps
Spring Clamps
Next, Spring Clamps are small, lightweight, and easy to use. They are perfect for holding small workpieces or for quick, temporary clamping.
Explore Spring Clamps
Guide Clamps
Guide Clamps
Guide Clamps are used to guide power tools such as routers and circular saws. They ensure straight and accurate cuts by holding the guide in place.
Explore Guide Clamps
Frame Clamps
Frame Clamps
Frame Clamps are designed for clamping picture frames and other rectangular workpieces. They ensure that the corners are square and the joints are tight.
Explore Frame Clamps
Mitre Clamps
Mitre Clamps
Mitre Clamps are used for clamping mitred corners, such as those found in picture frames. They hold the pieces at the correct angle while the glue dries.
Explore Mitre Clamps
Toggle Clamps
Toggle Clamps
Next, Toggle Clamps are used in jig making and other repetitive tasks. They provide a quick and secure hold, making them ideal for production work.
Explore Toggle Clamps
Hold Downs
Hold Downs
Hold Downs secure workpieces to a workbench or other surface. They provide a strong and stable hold, allowing you to work on the piece without it moving.
Explore Hold Downs
Strap Clamps
Strap Clamps
Strap Clamps are used for clamping irregularly shaped workpieces. They use a flexible strap to apply even pressure around the entire piece.
Explore Strap Clamps
Specialist clamps
Specialist Clamps
Finally, a range of specialist clamps designed to tackle unique clamping challenges that standard clamps can’t address effectively.
Explore Specialist Clamps
We are proud to stock clamps from a wide range of brands including:
In summary, woodworking clamps are indispensable tools that provide the necessary pressure to hold workpieces together during assembly and glue-up. Each type of clamp has its unique features and applications, making it essential to choose the right clamp for the task at hand. Investing in the right clamps will ensure that your woodworking projects are held securely in place, allowing you to focus on the craftsmanship and creativity that define your woodworking journey. Happy clamping!
Leave a comment
