Woodworking Wisdom
Woodworking Jigs - Overview
Woodworking Jigs - An Essential Guide
Woodworking jigs are indispensable tools that hold, support, or guide your workpiece or tools during operations. They ensure accuracy and repeatability, making complex tasks easier and more efficient. Whether you're cutting, drilling, or assembling, a jig helps you achieve perfect results every time. For detailed instructions on how to make each jig, check out our individual blogs on creating these essential tools.
Useful Woodworking Jigs
Here are some basic woodworking jigs that every woodworker should have in their workshop:
90 Degree Clamping Jig
Firstly, this jig ensures that your workpieces are clamped at a perfect 90-degree angle. It's especially useful for assembling frames, boxes, and cabinets, where precise right angles are crucial.
Mitre Spline Jig
Next, a mitre spline jig helps you add decorative and structural splines to mitred corners. This jig is great for reinforcing picture frames, boxes, and other projects with mitred joints, adding both strength and aesthetic appeal.
Bench Hook
A bench hook provides a stable platform for sawing. It hooks onto the edge of your workbench, allowing you to hold your workpiece securely while you cut. This jig is essential for making precise cuts without the need for clamps.
Shooting Board
A shooting board helps you plane the edges of your workpieces to achieve perfectly straight and square edges. It's particularly useful for fine-tuning the fit of joints and ensuring that your pieces are perfectly aligned.
Winding Sticks
Furthermore, winding sticks help you check and correct the twist in a board. If you place the sticks at either end of the board and sight along their top edges, you can easily see if the board is twisted and make the necessary adjustments.
T Square Bench Stop
Finally, this jig holds your workpiece securely in place on your workbench. It features a T-shaped design that fits into the bench's dog holes, providing a stable stop for planing, chiselling, and other tasks.
Cross Cut T Square
A cross cut T square is essential for making precise crosscuts. It helps you align your saw perfectly perpendicular to the workpiece, ensuring straight and accurate cuts every time. This jig is particularly useful for cutting boards to length and making precise joinery cuts.
By incorporating these jigs into your woodworking routine, you'll work more efficiently and achieve more precise results. Each of these jigs serves a specific purpose and can make your woodworking projects easier and more enjoyable. For step-by-step guides on how to make these jigs, be sure to check out our individual blog posts.
bench-hook
rider-shooting-board
spline-jig-against-router-fence
Discover more...
If you’ve enjoyed reading this article about woodworking jigs, keep an eye out for more woodworking articles to develop your knowledge and skill over time.
Connect with us!
Follow us on Instagram and Facebook to stay up to date on all the latest from our Woodworking Wisdom platform. Connect with us @AxminsterTools.
Leave a comment
