Blum CLIP-TOP 170 deg. Hinge & Cruciform Mount Plate With Screws
717590
717590
- All metal nickel plated hinge with 170° opening
- Spiral-tech depth adjustment
- Tool-free door to cabinet assembly and removal
- 3-dimensional adjustment (with mounting plate)
An all metal nickel plated hinge with 170° opening. It has Spiral-tech depth adjustment, tool-free door to cabinet assembly and removal plus 3-dimensional adjustment (with relevant mounting plate). Supplied with a nickel plated zinc die-cast cruciform with pre-mounted screws. Height adjustment ± 2mm.
Due to the nature of wide opening hinges such as the 170° CLIP-TOP, unavoidably a gap the diameter of a pencil can be inserted into the hinge. Therefore for child safety, we would advise where cabinets are accessible to children, safety latches should be fitted to avoid possible accidents.
- Height adjustment ± 2mm
- Supplied with a Nickel plated zinc die-cast cruciform with pre-mounted screws
