Blum TIP-ON Handle-less Opening Mechanism
AX923982
AX923982
- Handle-less mechanism for opening doors and drawers
- Doors open with ease at a single touch, To close, simply press shut
- Fits into the carcase end panel or use with adaptor plate
- 10mm diameter
- Long version option for doors over 1,200mm
Show more
Show less
This TIP-ON opening system for handle-less doors or drawers. Doors or drawers open as if by magic with a light touch TIP-ON fits into the carcase end panel or can be used with adaptor plate. It is quick and easy to install giving increased design options. Once fitted TIP-ON requires only a minimal force to open and close. The body is a mere 10mm diameter a long version is available for doors over 1,200mm.
Model | Short 07841770, Long 07841850 |
