Bosch 76mm Carbide Multi Wheel for GWS 10.8
- Laser-welded fine tungsten carbide grit
- Durable and capable of cutting a wide variety of materials
- Cuts wood and many more construction materials
- 76mm diameter, 10mm bore, 1mm thickness
This innovative and unique cutting disc fits the Bosch GWS 10.8V Cordless Angle Grinder and similar tools requiring a 75mm diameter disc with a 10mm bore. The steel body of the disc has fine carbide grit laser-welded around the rim resulting in an extremely durable and versatile cutting disc. This disc will cut wood and many other materials. The narrow kerf and expansion slots give a quick cutting speed and help avoid blade deformation. The disc offers a high performance and a long lifetime in multiple materials.
EAN Barcode | 3165140827621 |
Model | 2608623011 |
- Standard Delivery* - £1.99
