Gardens should be a haven; quiet and tranquil. The Bosch AdvancedHedgeCut 70 hedge cutter will do little to disturb the peace. This high-performance hedge cutter is up to 80% quieter than other comparable hedge cutters.
The AdvancedHedgeCut 70 tackles large hedge trimming work with quiet ease. There’s no compromise when it comes to power and performance. The 500W motor combines with a 700mm long laser-cut, diamond-ground blades to make short work of turning all and any unruly growth. The 34mm tooth spacing lets you cut through thick branches, whilst a slipping clutch protects the motor. A blade tip protector enables trimming close to walls and paths without fear of damaging the blade. This hedgecutter is perfect for trimming conifer, laurel, English yew, beech, holly, hornbeam, leylandii and viburnum hedges.
Trim medium to large hedges
Powerful performance with reduced noise
700mm blade length makes short work of large hedges
Blade tip protector for safe trimming along walls and paths
