When it comes to cleaning your patio, deck or driveway, a pressure washer is a great tool. However, they have a tendency to cover the surrounding surface, including the operator, with dirt and water as it ricochets off the surface. This is not the case when using the patio cleaner, the 280mm diameter round head houses the nozzle system; leaving the patio surface clean and the operator dry.
The AquaSurf 280 Patio Cleaner features a pivoting joint making patio cleaning a breeze. It is compatible with all Bosch AQT pressure washers from AQT 33-10 to AQT 45-14X models. It includes an extension lance to enable you to use the AquaSurf 280 comfortably at ground level without stooping. The nozzle system is enclosed and a brush skirt prevents spray, making cleaning the patio a highly satisfying job.
280mm diameter cleaning head, for cleaning decks, patios and driveways
