The Bosch C470 Delta sheets are suitable for use on wood, paint, varnish, filler, metal and more. The abrasive particles are semi-friable long lasting aluminium oxide grit. A calcium stearate coating minimises clogging, an especially useful feature when working on a painted surfaces or other materials that tend to clog.
These sheets give a perfect finish at high speed and are compatible with delta sanders from Bosch, DeWALT and others. The hook and loop backing offers rapid sheet changes. You can re-attach and reuse part used sheets making them even more economical. The pre-punched holes allow the use of dust extraction further extending the life of the sheet.
Single grit packs comprise 5 sheets; the mixed pack contains 6 sheets, 2 each of 60, 120 and 240 grit.
Aluminium oxide with hook and loop backing
Suitable for use on wood, paint, varnish, filler, metal and more
Calcium stearate coating minimises clogging
Pre-punched holes allow the use of dust extraction
